fish tank drain into house wastewater
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by donb, Oct 17, 2008.
  1. donb
    donb New Member
    Oct 17, 2008
    I am setting up my aquariums so that when I turn off the pumps, the water will drain into a tank to a level that will be above a 1" hole/bulkhead in the side of the tank.
    I want to gravity drain the water above this hole to the wastewater drain in my house. The closest drain pipe I have is about 8 feet from the tank and is the drain for the washing machine. The pipe is 3" black pvc that the washer hose drain stuffs into the top.
    Can I put a tee/wye/sanitary t on this pipe and drain the aquarium tank water into this pipe? If so what type of wye/tee should I use. What diameter pipe (8' run) and how much slope do I need. Should I use some kind of one-way valve on the aquarium tank drain pipe to make sure the washing machine doesn't backup into the aquarium?
    Any ideas would be appriciated.
    thanks
    don
Similar Threads: fish tank
Plumbing Forum, Professional & DIY Advice Water Feed Line For Fish Tank. Nov 24, 2009
Plumbing Forum, Professional & DIY Advice Fishing PEX through old pipe runs Jan 9, 2015
Plumbing Forum, Professional & DIY Advice Identify shower valve, Price Pfishter? Apr 5, 2013
Plumbing Forum, Professional & DIY Advice floor sucker pump for use in fish room Aug 1, 2010
Plumbing Forum, Professional & DIY Advice Zoeller pump for laundry tub in fish room Aug 1, 2010
