Washington
New well owner here in need of advice. Please forgive the long post, just want to give as much info on front end.
Problem: Lots of very fine sediment clogging our three one-micron filters, and subsequently reducing pressure. Changing all three filters every 1 – 3 days.
Failed solution: Tried to move to 5-micron in one of our three filters to help with the pressure. It helped, but the sediment that started coming through was bad enough to force us back to the 1-micron.
Professional advice: We’ve had two professionals try to help us, but there wasn’t a consensus – which makes us nervous. Both agreed the sediment is something called ‘glacial till’. The first man is suggesting a backwashing unit, the second one says the backwashing unit won’t help since some of the sediment is so fine that it doesn't 'settle at the bottom of a bucket' after letting it sit for 24-hours. The second man eyeballed our water and thinks it might be iron bacteria (water is being tested right now) and – pending test results - wants to run chlorine through the well for $3000. Trouble is, we have no other symptoms of iron bacteria (no smell, no rust).
Other problems (related?): Air coming out of one faucet each time it is activated, but no other faucet. Also, sometimes the water stops flowing in the kitchen when the washing machine is on in the basement. This typically only happens when pressure has already slowed. It will return again in 30 minutes or so. Basement shower can be reduced to trickle after basement toilet is flushed. Also only happens when pressure is already low.
Question: Is there a way to know for sure if a backwashing unit will help before paying thousands of dollars to install one? Should we be looking at other causes (pump/screen/low well)? Don’t mind spending money on a solution, just want more of a consensus on what the right solution might be.
Stats (if important): Two adults and one baby living in home. Low-water washing machine and dishwasher running every other day. Well has submersible pump and is about 35 years old. New bladder, but other service unknown. We have records of every time the filters were changed in the last five years (single occupant). Seems consistent with our experience – sometimes a month can go by without them being changed, then times when it is almost daily.
Sincere thanks for any advice.
