Fernco Wax Free Toilet Seal
Discussion in 'Toilet Forum discussions' started by McFee, Sep 2, 2005.
  1. McFee
    McFee New Member
    Sep 2, 2005
    I am having two new Kohler Serif two-piece toilets put in new construction by my plumber in a few weeks. He only uses the typical wax ring so I am somewhat reticent to suggest the wax-free seal before researching it a bit, or getting TL's advice. What is your opinion of this one Terry?
    http://www.fernco.com/FTS.html
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I've never used the Fernco ring, but Fernco is a well known brand in plumbing supplies. I have used both wax and Fluidmaster waxless rings with good success. You likely will never have a problem with a ring of any brand so I think you might just as well go with the flow, (pun intended) and let the plumber use the brand/style he is comfortable with.
  4. Kristi
    Kristi Tradesman Plumber
    Jan 27, 2005
    Tradesman Plumber
    Vancouver, BC
    Hey, what's wrong with wax? Just wondering as I've never had any issue with them...
  5. McFee
    McFee New Member
    Sep 2, 2005
  6. hj
    seal
    I have not used or seen the Fernco, but the ones I have used left we with less than an overwhelming vote of confidence when installed according to their directions, and installing them the way they made sense required two persons, one to guide the toilet with the waxless device into the pipe, and the other to actually lift and lower the toilet.
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    I think one advantage of wax rings is that you can shift the toilet some and still have a good seal. I seriously doubt that plunging a clog would ever blow out a seal, wax or waxless. Again I say you are worrying about nothing, but if it will make you happy, tell the installer what you want, it's your dime.
  8. hj
    plunger
    You are correct about the plunging. If the stoppage is past the seal, then plunging will do no good and it will also not develop excess pressure. If it is in the toilet where plunging might help, then it will not put any pressure on the seal. But in most cases if the seal starts leaking it was already doing it and the plunging just caused it to appear sooner.
  9. Kristi
    Jan 27, 2005
    Tradesman Plumber
    Vancouver, BC
    I vote wax!
    McFee, I've replaced many old toilets over the years - of course it's messy, they're meant to squeeze around the whole lot and keep that mess on the inside! After all, we know what's travelling down there decade after decade :)
    It's not rocket science landing those puppies square, I step one side down on it's bolt and then step the next side down - we have a positive landing! If the ring loses it's shape and seal from the bolts loosening, then that toilet has been left to rock for way too long... which tells me that it's doing its job better than you would expect. I have had nothing but easy and non-messy installations with them, but we all have our own favourites, now don't we... ;)
    enjoi!
Similar Threads: Fernco Free
Toilet Forum discussions Fernco Wax-Free Toilet Seal Jan 18, 2013
Toilet Forum discussions Fernco wax free seal and Drake toilet Nov 10, 2010
Toilet Forum discussions Fernco Wax-Free Seal VS. plain wax ring VS. wax + black plastic flange? Mar 27, 2007
Toilet Forum discussions Fernco wax less toilet seal reviews ? Jul 5, 2014
Toilet Forum discussions Wax ring vs. Fernco FTS-3 Dec 9, 2013
