faucet to pipe?
reddog2002
Washington
I;m installing a faucet that mounts to the wall with a separate line for cold and hot. It has 3/4 pipe threads to hook the supply lines to. How would you hook them up? I was planning on using the flexible copper pipe. It will be in an enclosed wall, But I can pull the trim off of a built in dresser and slid it out to get back in to the pipes if I need to.
Thanks Stacey
Master Plumber 101
Wisconsin
Thanks Stacey
What kind of faucet are you trying to install?
Redwood
Hmmmm
I don't see a vacuum breaker on the handheld...
Thiss looks very familiar to me...
Will the diverter shut off the water when set between the tub and handheld settings?
