Failed joint at shower head
Discussion in 'Shower & Bathtub Forum & Blog' started by wadswob, Jul 6, 2008.
  1. wadswob
    wadswob New Member
    Jul 6, 2008
    I finished plumbing a new bath/shower about 3 months ago. Just recently, I discovered water leaking into the basement. After some sleuthing, it appears that the joint between the copper pipe and the brass dog-ear at the shower head has failed. I have 2 questions:
    1. How did this happen? It was definately not leaking during the entire tiling process and for the first couple months of use.
    2. Is there any way to fix this without ripping the entire wall apart and redoing the joint?
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Are you sure its that and not the shower arm to drop ear elbow connection?
  4. wadswob
    wadswob New Member
    Jul 6, 2008
    Pretty sure. I can peek into the wall and wiggle the shower arm and see the leak. Actually, if I put some downward pressure on the shower arm, the leak stops.
  5. Redwood
    Dec 15, 2007
    Service Plumber
    Well then pretty much all you can do is open the wall and resweat the connection.
  6. hj
    leak
    How were you testing it during the "entire process"? The only way it can leak, and/or move is if it were a bad solder joint, and that should have started leaking almost immediately, unless the joint was just good enough to hold until something disturbed it. Now, you have to take the joint apart, you cannot just "resolder" it.
Similar Threads: Failed joint
Shower & Bathtub Forum & Blog Help - Major Damage from Failed Shower Pan Oct 18, 2009
Shower & Bathtub Forum & Blog My PVC Membrane Leak Test Failed Mar 20, 2008
Shower & Bathtub Forum & Blog Symmons Type B, failed attempt Jul 6, 2005
Shower & Bathtub Forum & Blog I failed my 'pre-glue' inspection... Dec 20, 2004
Shower & Bathtub Forum & Blog Understanding a Steam Shower Sealed Slip Joint: Photo's, Sketches and Video Tutorial Dec 7, 2013
