Experience with unusual shaped shower stalls?
Discussion in 'Shower & Bathtub Forum & Blog' started by Olivia54984, Nov 10, 2005.
  1. Olivia54984
    Olivia54984 New Member
    Nov 10, 2005
    Has anyone experience creating an unusual-shaped shower stall that would fit a neo angle pan, but have a slanted ceiling. The ceiling would start at about 7' AND 45 degree angle down to about 4' on one side. Obviously, I will be tiling the walls.
    Any problems, issues, thoughts?
  2. jeffreyhel
    jeffreyhel New Member
    Nov 4, 2005
    The last one I had to do I had to drop the ceiling even more to be have proper ceiling insulation. Unless you are going to do a fiberglass or acrylic base, have an experienced plumber install a lead pan. I replace pvc membrance pans 5 or 6 times a year in very expensive homes with gorgeous marble and that are only 1-10 years old. Plan out the shower curtain or shower doors well before hand. Try to squeeze in a shower lite.
  4. jadnashua
    From what I read, a PROPERLY installed membrane liner shower pan will outlast a lead one. Plus, if the liner is not installed on a sloped preslope (and a lead one almost never is), any moisture that gets down to the liner, and it will, will NOT drain out. Eventually, and this may take awhile depending on use, this stagnent water will start to smell like a swamp. Course, you could use something like Kerdi from www.schluter.com or make a really interesting shower using the www.wedi.de stuff from Wedi Fundo. They have a really neat free-standing tiled spiral shower (plus some others as well). Check out www.johnbridge.com for tiling info...first class site dedicated to tile.
  5. jeffreyhel
    Nov 4, 2005
    jadnashua, yes the material under a perfect install will outlast a leadpan. The problem is from the words on the page to the product actually getting installed are two totally different things. I have seen where the plastic shower strainers give out with the metal screws, nails way too low into the shower pan, actual holes that were done probably by the sheetrockers, bad corner folds, folds where the membrane turned a different color and split and the list just goes on and on. I have NEVER removed a 5 year old lead pan but have removed about 15 membrane pans that span from 1-12 years old in the last 3 years alone. Way too many in my opinion. Yes I do pitch the subfloor too which I find that almost no one does and I also drop the strainer into the subfloor so the lead is level going from the subfloor to the flange lip. The links you had are pretty cool.
  6. chassis
    chassis Engineer
    Sep 12, 2005
    SE Pennsylvania
    The only advice I can offer is on the ceiling, you may want to water proof it. This is due to the fact it would be somewhat directly in the spray path of water, and therefore it will be wet on a regular basis. You can waterproof it with Redgard, available at Home Depot, or you can use a waterproofing membrane such as Kerdi. Other than the ceiling, it sounds like you have a pretty typical shower installation.
Similar Threads: Experience unusual
Shower & Bathtub Forum & Blog tile redi shower pans Current comments/opinions/ experiences Feb 2, 2011
Shower & Bathtub Forum & Blog Toto Nexus and Trilogy High efficiency shower heads - your experience? Jul 14, 2010
Shower & Bathtub Forum & Blog Jaclo: Any opinions or experience with Jaclo Apr 8, 2010
Shower & Bathtub Forum & Blog Cast Iron tub damaged: Resurface? ...experiences wanted May 29, 2007
Shower & Bathtub Forum & Blog Any experiences with Kohler Purist shower doors? Feb 3, 2007
