Expansion Tank Issue?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gift15, Dec 27, 2009.
  1. gift15
    gift15 New Member
    Dec 27, 2009
    NY
    I have this water boiler, the expansion tank is upside down and there is no air vent. Then, many times there is no heat in the 2nd floor of the house [because the water doesn't reach up there].
    Is there a problem to the boiler that was installed? Would the upside down expansion affect anything? Also, the air vent is needed right?
    If, yes. What should I do or get fixed?
    Thanks.
    here is the picture I found of what a boiler set up should look like.
    [​IMG]
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    It makes no difference how the tank is mounted.
    If you get no heat upstairs you may have air in the system or not enough pressure. Pressure should be about 15 lbs.
  4. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Bad pump....?
Similar Threads: Expansion Tank
Plumbing Forum, Professional & DIY Advice Thermal expansion tank Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Installed expansion tank now pressure is higher? Aug 23, 2016
Plumbing Forum, Professional & DIY Advice Expansion tank location boiler? Aug 19, 2016
Plumbing Forum, Professional & DIY Advice Relocation Expansion Tank - Hydronic Heating May 4, 2016
Plumbing Forum, Professional & DIY Advice Need advice about expansion tank Apr 10, 2016
