Estimate on showerhead in tub...
Discussion in 'Shower & Bathtub Forum & Blog' started by linkjg, Jun 18, 2006.
  1. linkjg
    linkjg New Member
    Jun 18, 2006
    Estimate on shower head in tub...
    This is my first post to the board!
    My husband and I recently purchased a home that the tub does not have a showerhead. It has a faucet at the bottom, and plastic tile surrounding the tub (see pic). Could someone give me an idea on how much it would cost to have a plumber install a showerhead? Since the tile in the shower is plastic, would this cause a problem to install the showerhead?
    Thanks for any advice!
      File size:
      30.1 KB
      194
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    If you look really close on the valve side of the tub, you'll see a stubout above the shower wall that serves as the stubout for the future showerhead.
    The trim kit for the faucet will have everything you need to complete the task.
  4. linkjg
    linkjg New Member
    Jun 18, 2006
    Hi Rugged!
    Thanks for your quick response! Are you talking about this in the picture below? So, this is where the shower head would be installed?
    Thanks for your advice!
      File size:
      19.6 KB
      178
  5. Dunbar Plumbing
    Apr 18, 2005
    There is a vertical copper pipe going straight up to the horizontal wood block.
    That copper pipe is sweated into a brass shower lug ell that has a threaded connection for the future shower arm and head.
    There is a piece of galvanized pipe with a cap on the end of it. It's there for two reasons. One for the pressure test for leaks and the other is for when they drywall so that they don't cover that hole up.
    If that dimension is too high for your needs, they make numerous add on showerhead arms or better yet, a handheld shower can resolve the issue.
  6. linkjg
    linkjg New Member
    Jun 18, 2006
    Rugged,
    Thanks so much your post and your ideas!! I appreciate your help!!
Similar Threads: Estimate showerhead
Shower & Bathtub Forum & Blog Estimate to replace shower bed and liner Jun 21, 2016
Shower & Bathtub Forum & Blog Help!refernce of estimate......VIDEO!!! May 8, 2007
Shower & Bathtub Forum & Blog is this estimate high?Help! May 7, 2007
Shower & Bathtub Forum & Blog How can I avoid a leak from hidden flexible Handheld showerhead hose in a tub? May 22, 2014
Shower & Bathtub Forum & Blog Never ending leak on showerhead... Dec 17, 2013
