Epoxy Floor Covering
Discussion in 'Remodel Forum & Blog' started by Weaselpolooza, May 16, 2007.
  1. Weaselpolooza
    Weaselpolooza New Member
    Sep 11, 2006
    Michigan
    I have a 24' x 24' area (cement) inside of my shed that I am thinking about covering with the roll on expoxy floor covering. I have never done this before and according to the directions it seems fairly easy.
    Does anyone have any tips for applying this coating? I would hate for something to go wrong when I have already started applying the epoxy.
    Thanks!!!
  2. jimbo
    jimbo Plumber
    Make sure the area is clean and dry, and well ventilated. Epoxy is rather nasty to breathe in an enclosed area,
    The material will be in two parts. Mix well in the ration specified, and read up in advance what the working time is. Be ready to complete only the amount you can cover during that time frame. For an area as large as you suggest, about the size of a 2 car garage, I have done this a couple of times and do one half per session. That seemed to work well.
  4. Weaselpolooza
    Sep 11, 2006
    Michigan
    When you apply it in two sessions is it visible where you stop and then start again or does it blend in fairly well with itself. Also, is there really that big of a difference between the different grades of flooring (Basement, Garage, Industrial)
    Thanks Again!!
Similar Threads: Epoxy Floor
Remodel Forum & Blog Open Ended Question - Epoxy Grout Labor Jan 16, 2012
Remodel Forum & Blog Epoxy lining of H20 copper pipes?? Jun 6, 2008
Remodel Forum & Blog limitations of wood epoxy? May 23, 2008
Remodel Forum & Blog Bathroom subfloor 1/2" MDO plywood adhesive? Feb 19, 2017
Remodel Forum & Blog Bathroom subfloor question Aug 11, 2016
