Bmusgrove
I have a installed enamel steel tub that tilts towards the right front corner. While removing the wall for mold remediation and remodel I noted that that corner of the flange is rusting. Checking with a level shows the tub has a slight tilt to that corner, which is where the mold started.
That corner flange has started rusting on the vertical right at the angle, Starts at the bottom and goes unto the top.
Is there a good way to perform a lasting repair? It would be very difficult to brush it and clean it for a repair. Possible Naval rust destroyer or convertor, followed by Porcelain epoxy? JB weld?
Replacing the tub pretty much not a preferred as I will have to open up walls and ceilings to get to the plumbing.
