mikemass
Is it possible an element can:
1. Test good (I have continuity - 13.8 Ohms to be exact)
2. Receives power (I get 230 volts at the element when on)
3. Still not produce heat?
Reason I ask is because on my 120 gallon tank, I run out of hot water after about 10 minutes in the shower. Initially it is super hot, then at about the 10 minute mark, it just goes to pure cold. I checked the dip tube. it is indeed intact and sending the fill water to the bottom of the tank.
I am wondering if my bottom element can be so embedded in sediment that although it powers up, it can't heat the water down there? Any thoughts would be helpful.
