electrical wiring deficiency?
Discussion in 'Electrical Forum discussion & Blog' started by trackerxx, Feb 27, 2008.
  1. trackerxx
    trackerxx New Member
    Feb 27, 2008
    Hello:
    My gas dryer stopped working and since it was about 20 years old I thought nothing of it. (The dryer wouldn't start--it only made a buzzing noise).
    Anyway I had a new dryer delivered and the same problem happened! The dryer people said the new dryer was defective and said they would deliver a new one.
    My question is could the electrical outlet somehow not be delivering enough juice to start the dryer? I find this hard to believe since my old dryer was on this very same outlet for years with no problem. The outlet is hooked up to an old panel that has breakers. Wouldn't a breaker have tripped if there was a problem?
    Note: my house is old and the dryer is on the same circuit as other things. I also tried plugging in the dryer to another circuit with the same result.
    Any help is appreciated.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    An old electrical outlet certainly could have loose or damaged terminals, so that the dryer plugged in does not work. This would usually NOT trip a breaker.
    You said you plugged the dryer elsewhere and still no joy? Try plugging a lamp into where the dryer should be. Does the lamp work?
  4. trackerxx
    Feb 27, 2008
    yes
    Yes I plugged in a lamp, a hair dryer and a power drill and they all work fine.
  5. Mikey
    Nov 8, 2005
    Consumer
    Hansville, Washington
    Normally a dryer is a 220V appliance -- how did you plug in the test stuff? I'd first check to make sure you've got 220V across the 2 legs coming in. If only one leg is good (bad breaker, maybe), a lamp, drill, etc., would work OK if plugged into that side of the dryer receptacle, but the dryer itself certainly wouldn't heat up, and might have problems starting the motor. I'll see if I can find a circuit diagram of a "typical" dryer to check this.
  6. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    I would say that his dryer is a 120 volt appliance, what do you think?
  7. Mikey
    Nov 8, 2005
    Consumer
    My bad.
    Another case of RTFM, or in this case, RTFP...
  8. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    It's odd that both new and old had same problem...
  9. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    It's not odd if the problem is in the circuit in the house.
    You can have a circuit with a bad connection that will show that there is the correct voltage if there is no load, but will not conduct enough current to run the motor. The only way to check that is to measure the voltage when there is load on the circuit.
    You can usually (but not always) check it by measuring the voltage on the unused element of a duplex receptacle when the load is plugged into the first outlet.
  10. frenchelectrican
    frenchelectrican Electrician
    Jun 16, 2007
    Master Electrician
    NE Wis / Paris France { In France now }
    if that person did have backstabbed repectale that will useally show up or bad splices that is the curpit.
    Merci, Marc
Similar Threads: electrical wiring
Electrical Forum discussion & Blog Random electrical wiring questions May 27, 2013
Electrical Forum discussion & Blog Electrical wiring in India Mar 3, 2013
Electrical Forum discussion & Blog Rewiring a 200 Amp electrical panel Oct 13, 2009
Electrical Forum discussion & Blog Faulty Wiring - Electrical Fire Jul 21, 2008
Electrical Forum discussion & Blog Best Drill Bit for Electrical Wiring Jan 17, 2008
