electrical service anamoly
Discussion in 'Electrical Forum discussion & Blog' started by 99k, Jan 17, 2009.
  1. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    Last night I was awakened out of a deep sleep to three CO detectors (plug-in type) all blasting at the same time on two levels of our house. A very ominous sign ... It then became very apparent that something happened to our electrical supply since any lights turned on in the home glowed faintly (as if on a dimmer). Electronic thermostats and displays started flickering ... at that point I raced to the basement and throw the main in attempt to protect the house. At first I thought I may have lost a leg but then I would think some circuits would work and others wouldn't. It is -5F outside so it didn't take long for the home to turn into an icebox. Three hours later the utility company hadn't yet diagnosed the probrem, however, I decided to turn the breaker back on and it is back to normal? Any theories from the Electricians please?
  2. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Was it windy out? You could have a splice in the neutral and is freezing and pulling apart. Had that happen to me a few years ago, luckily it was only a hot leg, so just half the house worked. CL&Ps problem also.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    What brand is the main panel...sounds like possibly a lose neutral at the mast head connection if you have one or somewhere else...
    Was it windy?
    Is the panel Federal Pacific?
  5. 99k
    Aug 16, 2008
    I don't believe it was windy last night. We have a GE panel (heard bad things about the federal pacific though). I couple of years ago NE Utilities had redone the lugs at our transformer and mast because of a intermittent dimming of light (which I forgot about). This time though it was dimmed for at least five minutes straight before I realized It may damage motors etc and I threw the main.
  6. 99k
    Aug 16, 2008
    Just curious, if one leg works and the other doesn't, could a 220V motor such as the well pump operate or be damaged?
  7. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    nope, just wont work... You should really call an electrician to check things out just to be safe, CL&P could easily miss something, plus if the problem is on the inside its your problem anyways...
    The only time damage occurs is when you loose a neutral connection.
  8. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    124v on one side of the house and 116v on the other side means 4v across the (bad) neutral connection.
  9. rgsgww
    rgsgww New Member
    Jul 5, 2008
    Ia
    Sometimes it isn't on your side...maybe poco lines arced?
    Since you have a history of it happening before, I would have any main splices checked.
  10. 99k
    Aug 16, 2008
    I'm trying to get an answer to what the root cause was but my wife said there were numerous utility trucks at the bottom of our street and another mile up the road and so I suspect something happen to the lines... thanks for the feedback.
  11. rgsgww
    rgsgww New Member
    Jul 5, 2008
    Ia
    Probably is...around here we always get outages. Lights dim and alarm system acts up all the time.
  12. KE2KB
    KE2KB New Member
    Jan 17, 2009
    New Jersey
    First thing I would do in a case like yours is to check with neighbours.
    Also, I look out at the street lamps.
    FW
  13. GabeS
    GabeS Remodel Contractor
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    Are you positive there was no carbon monoxide? I know the whole house starting bugging out, but if the CO alarms went off I would still check it out on the off chance that both problems occurred at the same time.(electrical problem AND Carbon Monoxide leak). Probably chances are close to nil, but better safe than sorry.
  14. 99k
    Aug 16, 2008
    We're in a rural area - no street lamps and it was in the middle of the night so everyone's house was dark.
  15. 99k
    Aug 16, 2008
    Yes I'm positive ... in fact I cleaned the furnace and stack several days before. Once the power was back on, all CO detectors went back to 000.
  16. GabeS
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    Just checking.:)
    Also, carbon monoxide can be produced in several ways. One being not enough combustion air in the heater room causing incomplete combustion which produces CO.
Similar Threads: electrical service
Electrical Forum discussion & Blog Outdoor Fountain Pump Electrical Service Sep 20, 2013
Electrical Forum discussion & Blog What is the size of my electrical service (pics) Feb 2, 2011
Electrical Forum discussion & Blog service riser needs for an electrical service upgrade? Feb 12, 2010
Electrical Forum discussion & Blog 50 year old electrical service enterance Apr 14, 2009
Electrical Forum discussion & Blog Pool electrical question Apr 11, 2015
