Electric Water Heater Heat Loop
Discussion in 'Water Heater Forum, Tanks' started by Earnie, Dec 30, 2009.
  1. Earnie
    Earnie New Member
    Sep 7, 2009
    At Home
    I have a few questions on heat traps / heat loops.
    Are they worth the cost to install?
    Which is the better option, mechanical heat trap or passive loop?
    I have concerns that the mechanical heat trap will restict water flow. I can not find a 1" heat trap, only 3/4 inch. Would the loop be a better choice since it can be made of 1" pipe.
    If a loop is used, is it normally a circular loop of pipe or made with in a square with 90 degree elbows?
    Thanks.
Similar Threads: Electric Water
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Low amperage, lowest cost point of use electric water heater tank for low volume use? Jan 31, 2017
Water Heater Forum, Tanks Electric Water Heater Not Measuring 240V Nov 13, 2016
Water Heater Forum, Tanks Rules for electric water heater in manufactured home in Washington state Jun 3, 2016
Water Heater Forum, Tanks PEX near electric water heater Dec 25, 2015
