Easy to add a toilet to this basement?
Discussion in 'Toilet Forum discussions' started by Chuckledog, Feb 22, 2014.
  1. Chuckledog
    Chuckledog New Member
    Feb 22, 2014
    California
    Hi, first time poster, thanks for the great forum.
    We are considering remodeling our unfinished basement, one key factor being whether it would be easy to add a bathroom / toilet. Here's a pic of our current drain. It's a 4 inch pipe (possibly from the 1920's) going through a 45 to the underground drain line (not sure what direction that line takes). We would possibly break up the existing cement slab (very thin cement over sand, 1 foot below exterior grade). How hard would it be to plumb a toilet into this line? It goes to the city sewer line 70' away.
    If the pictured area is not suitable, would we be better off tapping into the drain line further downstream?
  2. jadnashua
    you'd need to know how deep the line runs under the slab, and what direction. Plus, you'd need to add a vent for at least the sink and tub/shower. That cap is a cleanout. If you can get it off, you may be able to see how deep the line goes before it turns. If it isn't very deep, you might be limited to a toilet with a pump, one example is made by SaniFlow.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The only connection you can make will be under the floor in the horizontal section of pipe going out of the building.
    Commonly there will be a cleanout in the yard to the outside of the foundation wall that could be used to give you a good idea of the path of the pipe under the floor.
  5. hj
    In any event, there is more to adding a bathroom down there, than just making a connection, (that may be the EASY part), and running some pipe. Since this is something that was not anticipated, there is probably not an accessible vent line for it.
Similar Threads: Easy toilet
Toilet Forum discussions Moving toilet 3 inches if easy access? Mar 16, 2013
Toilet Forum discussions easy clean toilet seat Oct 3, 2004
Toilet Forum discussions BurCam easy flush system Mar 4, 2017
Toilet Forum discussions How easy/hard/expensive to extend the rough-in distance a little? Sep 14, 2010
Toilet Forum discussions Easy being green, Central PA Magazine August 2008 issue Apr 4, 2010
