DWV Fittings check for bathroom & laundry (Ontario, Canada)
riverdale
Ontario
Now that the layout has been determined (previous post), I’m looking at individual fittings for specific locations of the DWV system (Ontario, Canada).
Can somebody please tell me if what I’ve indicated on the attached diagram shows the *CORRECT* fittings for those locations?
A few specific points, mostly to give me options if I am tight on access/space:
LOCATION A & B:
Instead of a Long Turn 90, would 2 x45 also be acceptable here? Just *NOT* a medium 90.
LOCATION C:
Can a WYE used in a vent situation be entirely horizontal? Or does it have to be slightly rotated above horizontal, or must it be completely vertical?
LOCATION D:
A horizontal SAN-TEE *cannot* be used here, it must be a COMBO WYE or a WYE + 45, correct?
LOCATION E:
If extra physical space is needed between the washing machine SAN-TEE and the SAN-TEE for the sinks, can a WYE be used here (vertically) to get the standpipe connection down a little lower on the main stack.
Thank you very much.
riverdale
Ontario
Mmmm......any takers here? Just looking for a confirmation the fittings I’m planning on using are correct and I haven’t missed something. If there’s anybody out there that can provide a thumbs up or thumbs down based on my diagram I’d appreciate it.
Thank you.
Just to confuse you a little bit more, I would use a Y or 1/8 bend at A&B wuth a 1/6 bend rolling into it.
C in many areas you CANNOT run the vent horizontal in the first place
D if the inspector allws the vent at that location then a combo would be used for the drain
E. you cannot connect an unvented branch to a vertical line with a combo or Y.
riverdale
Ontario
Thanks HJ, you're the best!
I think I've got ya.....
A & B: I think what you're getting at is make the transition as smooth and gentle as possible. So a LT 90 isn't *wrong* it's just even better if done with your set-up? Which should be doable. Having said that, currently there are FOUR 90's and a 45 leading to Location A over a 3' horizontal and 1' vertical distance, so just about ANYTHING I replace it with should be an improvement!
C: Looking at it again I think I can just about squeeze in a vertical vent connection there so that shouldn't be an issue.
D: Great, the wall is 2x6, so again, shouldn't be a problem space wise getting that in there.
E: Ahhhh, so my two SAN-TEES are fine as shown and if I'm understanding correctly I *could* use a COMBO or WYE on the sink branch, *if* necessary due to height/space, because it IS vented. Whereas the standpipe branch IS NOT, thus no COMBO or WYE, only SAN-TEE.
Thank you again so much, it is truly appreciated!
Would D have been allowed by your inspectors, even with the combo?
riverdale
Ontario
At this point I don’t know, but it was discussed towards the end of my previous thread about the initial DWV layout. Two solutions were presented (this option with central vent and west side drain, and a central drain with vent directly above) but I was going with this 2 sink vent setup to hopefully avoid the elusive double fixture fitting.
Two vents over two santees would be liked by everybody if the drain pipes are 2 inch and the drain tee was combo or wye+45.
riverdale
Ontario
Just so I'm not misunderstanding you.....Do you mean like this shown in the diagram excerpt below?
- The drains will be 2" (except the sink traps @ 1.5")
-The "left" sink at location D will be tied into using a combo.
-This two sink branch will tie in with a SAN-TEE above the washer standpipe SAN-TEE.
-The vent coming up off the middle of the two sinks will be 1.5" and vertical all the way.
-The main stack is 3" and vents directly to roof.
Thank you for your help.
Bonus. The standpipe now has a dry vent, so no concern about whether a wet vent is OK.
Re-looking, maybe I should have drawn the drain line horizontal in line with the drain line going off to the left.
