Hello,
While I'm pretty handy around the house, plumbing is pretty new to me.
I replaced a 60" single sink vanity, with two 25" vanities. Now after everything is hooked up, neither sink will drain the water at all it seems. My configuration is as follows:
-One 1 1/2" P trap right in between the two vanities, leading into the wall.
-Above the P trap I put a center split waste pipe (looks like a "T"). The top of the T sits about 4-5" higher than the pipe coming out of the wall.
-From the T split, there are about 18" to each sink drain pipe. There's not a big pitch from the sinks to the center waste, just a very slight one.
Any ideas on what I can do to fix this? I was reading that some people put a p trap under each sink. Is this the better solution?
Thanks.
Alex
Thanks.
Alex
