Drop-in Whirlpool
Discussion in 'Shower & Bathtub Forum & Blog' started by Bob1234, Apr 13, 2008.
  1. Bob1234
    Bob1234 New Member
    May 31, 2006
    I'm replacing a Kohler Memoirs whirlpool (which was defective) with another. Plumber "A" installed the drop-in tub using a mortar base as the "feet" of the whirlpool were about 2.5 inches off the enclosure floor. Plumber "B" removed the old tub and mortar. The second tub was again dropped on the enclosure lip, the "feet" were again off the enclosure floor, and he elected to use an expanding foam between the feet and the floor. The install instructions stated that either a mortar based or wood shims could be used. I'm not sure if Plumber "B" method is ok or not. I'd prefer to not fall through the floor while using the whirlpool, or have the tiled enclosure lip break. I'm thinking of placing wood shims under the whirlpool at both ends and the middle. Maybe this is too much -- I just don't know. All advice would be greatly appreciated.
    Bob
  2. hj
    support
    Expanding foam under the feet is useless. It has to be between the floor and the tub bottom to support the unit. You can use mortar under the feet because that will not crush under a load.
  4. Bob1234
    Bob1234 New Member
    May 31, 2006
    So, if the entire area between the bottom of the whirlpool and the enclosure was "foamed", then would that be ok, or does the whirlpool have to be removed and a mortar base be used?
    Again, thanks in advance
    Bob
  5. westcoastplumber
    westcoastplumber Plumbing Contractor
    Nov 30, 2007
    c-36 plumbing contractor
    los angeles
    I have cut wood shims, used them, then used a can of spray foam to hold them in and insulate the the bottom of the unit to reduce sound.
    the foam holds the wood shims in place.
    I have also used mortar.
    just foam alone is worthless.
  6. Bob1234
    Bob1234 New Member
    May 31, 2006
    So, what about removing the foam from the tub feet, using wood shims (probably 2x4's) between the feet and the floor, not using mortar, and then just omitting the foam altogether? Would I be ok then?
    Bob
  7. westcoastplumber
    Nov 30, 2007
    los angeles
    As long as the shims are tight under the "legs", go ahead and foam them in, and then use can foam to do under the tub also, this will help insulate from noise and viberation.
  8. Bob1234
    Bob1234 New Member
    May 31, 2006
    Update. I removed the foam and used 2x4 and 1x4 to shim the four corners and one center leg. Seems very stable and took the weight off of the enclosure's tiled top. I'm going to separately foam around the shims and the tub bottom. Thanks again. This was a much better way to retro-secure the whirlpool without removing it , using mortar, and then re-setting it. It also reduces the weight on the support beams. Great help. Thanks.
    Bob
Similar Threads: Drop-in Whirlpool
Shower & Bathtub Forum & Blog Drop-in Whirlpool Tub install Mar 7, 2006
Shower & Bathtub Forum & Blog Drop-in surround Dec 11, 2012
Shower & Bathtub Forum & Blog Drop-in Tub Overflow Interference Question May 17, 2011
Shower & Bathtub Forum & Blog Waterproofing drop-in tub deck Mar 17, 2008
Shower & Bathtub Forum & Blog deck for drop-in tub Jan 31, 2008
