1. Lostinmichigan
    Lostinmichigan New Member
    Mar 25, 2008
    What is the best type of point and pump set up to use/ Here in this area of michigan it is common to have regular wells around 35' deep and have excellent water flow, so i figure a point will have to be around the same depth. is this to deep for a shallow well pump set up?
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    It doesn't depend on how deep the point goes; it depends on how far the water is below the surface after you hit water.
    You could ask your neighbors if they are successfully using a shallow well pump.
    The usual shallow well pump limit is considered to be 25 ft to water, although the theoretical limit is more than 30 ft. You gain some if you put the pump in a full basement, which is pretty common in residential construction in Michigan.
    I have seen flowing wells in Michigan where the water flows out of the pipe at the surface.
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Where in Michigan?
    bob...
Similar Threads: driving point
Pumps and Tanks Well Forum & Blog. Water is life. Driving Well point Aug 25, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Driving a sandpoint well. Please help Sep 16, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Driving well point in basement ??? Jun 9, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Questions about driving a new sandpoint well Apr 28, 2008
Pumps and Tanks Well Forum & Blog. Water is life. problems Driving a Sand Point Aug 29, 2007
