Drip Trap for Propane Appliances
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by FredC, Mar 3, 2007.
  1. FredC
    FredC New Member
    Feb 17, 2007
    Do You need to install a drip trap on a vertical line going to a cook stove. I have 14 ft of 3/4 balck pipe coming down through the wall to a cook top. Should I add a tee and a 6" nipple with a cap to the end at the bottom. The source is LP gas. Thank you.
    Fred
  2. hj
    drip
    We don't even use them with natural gas any more.
  4. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    If you have the material and ability, I would...
    Put the tee in, a 3" nipple, a ball valve and another 3" nipple with a cap...
    If and when you do decide to "clean out" the dirt leg, just close the valve, remove the cap and clean it...
    Then replace the cap and re-open the valve...
    You may never need it, but if you do, the valve is a good idea...
  5. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    When our gas meter was replaced a year or so ago, the worker came inside to check for unlit pilots and so on, and when our furnace would not light itself, he pulled the cap off that "drip trap" or "dirt leg" for a few seconds to purge the air from the line ... and that is why I would install one.
  6. coz
    coz New Member
    Feb 27, 2007
    MA
    Its designed to catch scale and moisture. i have pulled drip caps and gotten enough water to block the line.(in a commercial building) They are required by code in my state.
Similar Threads: Drip Trap
Plumbing Forum, Professional & DIY Advice Gas water heater-- sediment trap / drip leg length Feb 22, 2015
Plumbing Forum, Professional & DIY Advice Dripping faucet Jan 26, 2017
Plumbing Forum, Professional & DIY Advice American Standard Single Lever drip behind cartridge Dec 1, 2016
Plumbing Forum, Professional & DIY Advice Found a new drip. Causes? Oct 13, 2016
Plumbing Forum, Professional & DIY Advice delta single handle faucet drip Jan 3, 2016
