Drain size
Discussion in 'Shower & Bathtub Forum & Blog' started by jpiazza, Feb 11, 2008.
  1. jpiazza
    jpiazza New Member
    Jun 11, 2007
    Hi. I have two questions pertaining to a shower remodel. One, I will have 4 or 5 shower heads producing a total 10-12.5 GPM. If everything is pitched and vented properly will a 2 inch drain be sufficient to get rid of the water? Second, does anyone have a suggestion as to how far apart body sprays can be to be effective? I'm thinking of putting in a 60x32" shower pan and putting the sprays on the 60" opposing walls. Thanks
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    Yes, it will be fine , assuming the pipe is clear of any blockages
    The sprays can be as far apart as you need them . Depending on how big you are. LoL :p :p J/K
    Its a personal preference. If you stand in the shower stall, how much of the water sprays do you want hitting you?. Those body sprays should be adjustable {up, down, left and right}, like a regular shower head.
    I also recommend to create a continueous loop from the first spray to all other sprays, and end back to the first head. That will ensure equal amount of pressure and flow from each body spray
  4. jpiazza
    jpiazza New Member
    Jun 11, 2007
    Yes, the heads are adjustable. I just want to make sure I'm not standing in the shower and the sprays are hitting me from the waist up. I am dealing with about 45 psi. Thanks
Similar Threads: Drain size
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Feb 25, 2017
Shower & Bathtub Forum & Blog Need help with a drain size Jun 20, 2016
Shower & Bathtub Forum & Blog Question on trip lever tub drain-bucket size universal? Aug 31, 2014
Shower & Bathtub Forum & Blog Shower Drain Size and Code Feb 17, 2012
Shower & Bathtub Forum & Blog drain and overflow hole size and compatability of tub waste /drain Aug 6, 2011
