Don't Understand This Problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by WV Hillbilly, Jan 2, 2009.
  1. WV Hillbilly
    WV Hillbilly New Member
    Aug 1, 2008
    WV
    My kitchen faucet has a spout that swivels . There are two rubber o-rings that seals the spout . The faucet spout was leaking where it swivels so I took it apart & cleaned the o-rings , the grooves they fit in , & the inside of the spout . The o-rings fit tight in their grooves . I didn't use any type of cleaning product , just wiped everything clean with paper towels . I put everything back together & lubricated with Harvey's brand plumbers faucet & valve grease . The next day I noticed that the spout was hard to swivel back & forth . Today I took the spout back off & found the o-rings no longer fit tight in the grooves & actually drooped over the sides of the grooves . I plan to purchase new o-rings tomorrow & am at a loss as to what caused the o-rings to do this unless it was the grease . Has anyone else ever had a probem like this ? I'm afraid to use the grease on the new o-rings .
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    That Harvey's grease?
    It was a grease with a petroleum base.
    Probably light brown when applied, turns really dark brown over time. That is not supposed to be used for anything other than screw threads, or anything that does not come in contact with rubber components or water.
    Need to use the food grade type, the kind that looks like silicone that never hardens, has no smell whatsoever. Much doesn't come in the container but I use it for practically everything these days.
    That grease swelled those rubber O-rings out and destroyed them.
  4. WV Hillbilly
    Aug 1, 2008
    WV
    Thanks , figured it had to be the grease & I'll buy the correct type .
    Just picked up the tube & reread the directions on the tube . It says , apply to stems of faucets , valves , ball cocks , plungers , packings and washers . Frees sticky faucets . Prevents rust . Use on hot water or steam to 350 degree F . Prevents pinching and allows easier installation of "0" rings .
  5. chrisexv6
    chrisexv6 Member
    Oct 6, 2008
    You can also try any decent o-ring lube sold at swimming pool stores. I think Jacks Magic is one brand, should be petroleum free, silicone based. I use it for o-rings on my pool filter, and havent had one go bad yet even after 5 seasons of chlorine exposure.
    Use it sparingly......I usually put a dab on the oring and then circle the oring thru my fingers to spread it.
  6. WV Hillbilly
    Aug 1, 2008
    WV
    I went to the local Ace Hardware this morning & picked up the o-rings I needed & 90 % silicone faucet grease . Cleaned the spout assembly real well & put everything back together . So far all is well with the faucet . Even though the Harvey's grease said to use it on o-rings I think Rugged is right & it messed the o-rings up . Only feasible explanation for what happened to the old o-rings . Thanks guys .
Similar Threads: Don't Understand
Plumbing Forum, Professional & DIY Advice Shower Drain For Fiberglass Shower - Caulk Or No-Caulk Design - Do Or Don't Do? Dec 11, 2015
Plumbing Forum, Professional & DIY Advice Yep...Don't Solder too close to the wall... Jan 21, 2015
Plumbing Forum, Professional & DIY Advice Pipe Noise/Vibration; Different catalysts; Don't want to outright call it hammer Dec 24, 2014
Plumbing Forum, Professional & DIY Advice Sink / Wall positioning so I don't need to reroute plumbing under concrete Sep 17, 2014
Plumbing Forum, Professional & DIY Advice True or False? If sweated joints don't leak right away, they won't ever leak. Mar 19, 2014
