Does this new DWV System appear to meet IPC Florida code?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Stephanie Maps, Apr 14, 2013.
  1. Stephanie Maps
    Stephanie Maps New Member
    Mar 6, 2013
    Florida
    After many hours of reading code and reading old posts on this forum I've managed to design this small DWV system for a new cabin.
    Please review the following 5 images and let me know if anything appears to NOT be legal for Florida's IPC.
    The PN# referenced in the jpgs come from Charlotte Pipe's PVC DWV Dimensional Catalog
    Thanks in advance,
    Steph
    1. Overall Layout
    2. Shower & WC Closeup
    3. Lav & Utility Sink Closeup
    4. Kitchen Sink Closeup
    5. Vents Closeup
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    No, no and NO. And Florida is an IPC state. Most of your vents are flat.
  4. Stephanie Maps
    Mar 6, 2013
    Florida
    lol omg that is funny.
    YES ok yes Florida is IPC. Thaaaat's what i meant to say.:eek:
    And good eye Tom Sawyer, you are correct I failed to slope the horizontal runs of the vent. I can fix that. Thank you.
    Anything else here that does not met IPC florida?
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    It's not just a matter of pitch. The vents must be vertical until they are at least 42" above the floor. Your drain routing will need to be changed to accommodate the vents.
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    You also will need to lose the vent tee on the utility sink. You cannot use vent components for drainage. Is also appears that the sink is on the floor, with the trap below the floor, so I am guessing that the drawing is wrong.
    I'm sure others will pipe in, as I am on my way out the door.
  7. Hammerlane
    Hammerlane Member
    Oct 22, 2011
    The wye you have taking off for the stanpipe vent should be turned the other way..allows for "smoother" air flow drawn it from vents and also allows for proper draining if/when water gets into vents. But as others have said you have some flat vents also.
  8. Stephanie Maps
    Mar 6, 2013
    Florida
    Oooh is THAT what Tom Sawyer meant by "Most of your vents are flat." Not the he had eagle eyes and could tell that the horizontal vent pipes forming branch vents were not sloped but that leaving the Ptrap many of my vents do not go vertical nearly enough before going horizontal.
    Thank you SO much for clarifying what he meant by that.. NOW i understand is not just and slight issue of pitch but of the entire layout.
    A "flat vent' is a vent that does not meet the following-
    Thanks cacher_chick, now i understand. :eek:
  9. Stephanie Maps
    Mar 6, 2013
    Florida
    Ok, good eye that makes sense. I'll figure out the right series of fittings to use under a double sink. I used the same (wrong) configuration on both the kitchen and utility sink. - thanks again.
    Here is better perspective of the same layout. I hope it makes more sense.
  10. Stephanie Maps
    Mar 6, 2013
    Florida
    Thanks Hammerlane regarding the position of the wye on the vent of the lav sink. That is a great drawing you used to show turned the other way.. I get it! :)
    However, in that instance i am trying to get to the other side of the wall in that direction.. in the direction it is currently orientated. And am going up at a 45deg to avoid creating a flat vent there.. soooo even though it might not provide the smoothest airflow at this point I am merely trying to determine what is LEGAL.
    I think you are saying that although it might be legal under IPC to use wye in the manner i have it- better airflow is achieved turning the wye in the other direction.
    The flat vents I am showing on the shower and water closet are my only real concern at this point. But they are big ones.
  11. hj
    quote: soooo even though it might not provide the smoothest airflow at this point I am merely trying to determine what is LEGAL.
    It is NOT legal because it goes against the flow of the drain line, and has nothing to do with "smooth air flow".
  12. Stephanie Maps
    Mar 6, 2013
    Florida
    oh really?
    I had no idea. I clearly did not understand his comment the first time then. Thanks for clarifying that for me - I thought he was saying it was legal but not ideal.
    You guys are awesome!
    Just so i understand what you are saying.
    " SECTION P2607 WORKMANSHIP
    P2607.1 General.
    Valves, pipes and fittings shall be installed in correct relationship to the direction of the flow..."
    And the CORRECT direction of flow for a wye fitting is ALWAYS in the direction shown here.
    It does not matter if the wye is used for a drain or a vent, if it is horizontal, vertical or sideways. When i see a wye i should think strictly in terms of
    Is that correct?
  13. suceress
    suceress Member
    Mar 12, 2008
    LA
    I know I don't have any helpful information, but I'm wondering what program you used to get the layout of the pipes. I'm also curious about where and how the stand pipe hooks in. I'm trying to plan out a bathroom/laundry room as well and am trying to figure out the correct order in which to connect things. So far the info in this thread has been enlightening.
Similar Threads: Does System
Plumbing Forum, Professional & DIY Advice Small Radiant heat system - Does this look right Dec 23, 2016
Plumbing Forum, Professional & DIY Advice Does Building Plumbing have systems that ~flush~ the lines Dec 28, 2015
Plumbing Forum, Professional & DIY Advice Revision 2 of DWV System - Does this meet IPC Florida ? Apr 18, 2013
Plumbing Forum, Professional & DIY Advice 2 zone system-no heat upstairs-Boiler doesn't fire when that zone asks for heat Dec 7, 2010
Plumbing Forum, Professional & DIY Advice OK Kids... How does this look. My First DWV System Nov 13, 2007
