Timothy LaDuca
I recently made a plumbing discovery. My father is/was a big DIYer. Whenever he needed to do maintainence under a sink and remove the P-Trap, he'd get a bucket to catch all the nasty water that was in the P-trap and above it to the height of the drain line. I did some experimenting and I realized I could "flush" my kitchen sink by simply filling it and waiting for any turbulence to die down and removing the stopper (carefully as to not introduce excess turbulence) the water would drain and "flush". I knew it was flushing because there was such a sucking sound when the water finished emptying the sink (which sound I don't normally hear). Curious, I removed the P-trap, suspecting the water in the P-trap should be no higher than the top of the bend. Indeed that was the case. No mess, just a little water in the bottom of the P-Trap. Is this plumbing 101 or just a waste of time? I demonstrated this to my father (before investigating the P-trap, nor even thinking of it) and he was impressed by the sucking force (as was I) which won't happen if there is turbulence because you get angular momentum and a whirlpool (funnel) which prevents the water from evacuating at full force and/or introduces air into the flow preventing a complete siphoning.
