Dividing 3" hose pipe to 5 sprinkler
Discussion in 'Irrigation / Sprinkler Forum' started by misango, May 2, 2012.
  1. misango
    misango New Member
    May 2, 2012
    mwanza
    Hi there, i have managed to get 3" petrol honda water pump which I think will be suitable for my small farm irrigation, the source of water is the lake.
    I just wanted to distribute the water using 3/4" water pipes to five sprinkler so that it can be easy to supply water to a larger area for a short time. now the problem comes that when I turn the pump at the highest speed the pump shut down it self, and when I turn the pump at the medium speed the pressure reduces and the sprinkler does not supply water to large area.
    Does and one have an idea on how to distribute water and what else should i do in order to achieve a high pressure at the sprinkler.
    Thanks in advance.
Similar Threads: Dividing hose
Irrigation / Sprinkler Forum Are There Any Hose Bibs Designed for Continuous Use? Yesterday at 4:27 PM
Irrigation / Sprinkler Forum Is it against code to connect a timer to a hose bib? Saturday at 8:49 AM
Irrigation / Sprinkler Forum Simple garden hose sprinkler on Well pump issue Jun 25, 2016
Irrigation / Sprinkler Forum Pipe size for hose bibb Jun 19, 2016
Irrigation / Sprinkler Forum Adding hose bib Mar 2, 2014
