Diverter confusion in Ohio
Discussion in 'Shower & Bathtub Forum & Blog' started by despec, Jul 16, 2007.
  1. despec
    despec New Member
    Jul 16, 2007
    Sorry for the duplicate post from the "General" forum, but missed this forum where my question really should be:
    Hello to all,
    First off, my apologies if this becomes long and a bit disjointed. Confusion reigns supreme in my plumbing knowledge.
    I'm having a problem with the diverter stem on my shower. I believe it is a Briggs unit because around two years ago, I replaced both the hot and cold stems with Briggs stems (534NS) from Dinapolli Plumbing online. I also orders the diverter stem, which I'm assuming was also a Briggs. Just recently, I noticed that when the diverter valve was turned counter-clockwise to 'activate' the shower, cold water started leaking out of the cold water stem (through the escutheon). I removed the diverter and noticed that a washer (not sure what this one is called) over the stem that sits against the bonnet nut was dislodged and just running loose over the stem. Could this be causing the leak? What is this washer called and where might I find it. I could not locate this washer anywhere at Home Depot or Lowes. And if all else fails, does anyone know where I might find a new diverter?
    Lastly, does anyone have a good diagram of a diverter and the pieces/washers attached?
    Any help would be greatly appreciated,
    David in Ohio.
    Edit/Delete Message
Similar Threads: Diverter confusion
Shower & Bathtub Forum & Blog help finding shower head diverter Jan 28, 2017
Shower & Bathtub Forum & Blog Upgrade Manufactured Home 2 Handle Valve with Bath Shower spout and diverter Jan 11, 2017
Shower & Bathtub Forum & Blog Is this Grohe leaky tub spout diverter repairable?? Jan 2, 2017
Shower & Bathtub Forum & Blog Piping and a 3 way diverter in shower Nov 15, 2016
Shower & Bathtub Forum & Blog Replacement Delta bath faucet/diverter Nov 2, 2016
