Distribution Header
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by clemkonan, Aug 1, 2009.
  1. clemkonan
    clemkonan New Member
    Aug 1, 2009
    I am trying to understand if its just me or if others agree that houses should be piped using a functional distribution header which will allow water to be easily shut off to different parts of the home .
    For example a leg would supply kitchen so that if I wanted I could attach a distilled water unit on that line and easily provide distilled water to the kitchen. Of course the most immediate benefit would be the ease with which one cut cut water to one area of the home do a repair on another leg and not inconvenience a lot of folks.
    I would still keep my shut offs at source for example leg 2 could supply the upstairs bathrooms and I would want a shut off on the flush and the shower.
    would be nice to hear from the experts.
    And yes you can buy a $400,000 house and not get a shut off on the flush.
    Regards
    Clemkonan
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Good idea but remember, it's all about the money. Most houses are built by contractors that want to get things done as cheap, ok inexpensive as possible.
  4. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I prefer a proper branch supply system with a recirc line.
  5. clemkonan
    Aug 1, 2009
    Where can I get information on such a design or see a flow diagramme?
  6. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I'm talking about a typical system. 3/4" hot and cold mains with 1/2" branches and recirc line back to the heater in a very basic description.
  7. hj
    stops
    Two problems with your design, besides the cost.
    1. The average plumber servicing the house would not know about them or where they are located. And even if he did know they were installed, he would probably prefer to use an alternate means of shut off to avoid problems with them, (see reason #2.)
    2. The majority of those manifold valves are fairly poor quality and do not endure many on/off cycles before they fail.
Similar Threads: Distribution Header
Plumbing Forum, Professional & DIY Advice Home run water distribution system? Apr 15, 2016
Plumbing Forum, Professional & DIY Advice Water distribution re-plumb Nov 23, 2014
Plumbing Forum, Professional & DIY Advice Modified Home Run Pex Water Distribution System Feb 27, 2014
Plumbing Forum, Professional & DIY Advice Required fittings between distribution line and fixtures? Oct 31, 2012
Plumbing Forum, Professional & DIY Advice Water supply and distribution plans - Seattle home Jan 22, 2012
