cds0020
I have a small U-shaped kitchen and had to put the dishwasher around the corner from the sink, which is on the small end of the U. I have a 48" long corner cabinet to go through before I can tie the drain line into the disposal. I am trying to figure out the best way to run the drain line. I see 3 options:
1) Run the drain line below the cabinets along the floor. Then come up through the bottom of the sink cabinet and make a high loop before hooking to disposal. There is room under the cabinets to do this and it would be the easiest and cleanest option if it would work. I'm worried about water sitting in the pipe as it runs along the floor, but wouldn't this happen in all cases?
2) Drill a hole HIGH in the corner cabinet beside the dishwasher and run the drain tight to the countertop. When I come into the sink cabinet, would I don't think I would need a high loop? Or would running tight along the countertop count as my high loop?
3) Drill hole in middle of cabinet and run drain line under middle cabinet. Then high loop in sink cabinet.
