Direct Vent Fireplace - Snorkel
Discussion in 'HVAC Heating & Cooling' started by The old college try, Dec 4, 2010.
  1. The old college try
    The old college try Engineering Technician
    Jan 31, 2007
    Anyone have any experience with venting direct vent fireplaces? I picked up a gas free standing stove that I'm planning to install. I'll likely do the venting myself and have the gas line run down by someone else. It'll be a below grade installation, and Im quite sure I'll need a snorkel to raise the height of the vent since it will only be about 12" above grade where it exits the wall. I keep reading that the vent needs to be 12" above the highest anticipated snow level. Does anyone know here I can find that height for Michigan? Looks like the snorkels come in 14" and 36" heights. If I can get away with the 14", I will, but with my luck I'll have to spring for the 36" job. Those crazy things are like $400. Anyway, any help would be appreciated. Secondly, is it possible to cut into the middle of a gas line to install a tee, or would it be more cost effective to disconnect the line back to a union or something to add a drop for the fireplace. The stove will be right below the existing gas line.
Similar Threads: Direct Vent
HVAC Heating & Cooling Direct vent clearance to outside corner Feb 17, 2015
HVAC Heating & Cooling Direct Vent Stove Install/Ansi Rating Oct 21, 2011
HVAC Heating & Cooling transformer gasket not enough to prevent indoor odors in direct vent? Dec 16, 2010
HVAC Heating & Cooling Direct Vent Boiler Into A Standard Flue? Oct 5, 2008
HVAC Heating & Cooling Connect Direct Vent WaterHeater to chimney flue? Feb 28, 2008
