Dip tube question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Gary Swart, Feb 16, 2007.
  1. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I have a 10 year old 50 gallon Richmond gas water heater. Recently I have noticed that when I begin using hot water, like showering, the water is quite hot, but after a few minutes, to maintain the hot temperature, I have to keep advancing the temperature valve until finally reaching the point where it is in the full hot position. I have not found any debris in my screens, and I have drained the tank and I didn't see any debris there either. Is this the way a failed dip tube word act? Any other ideas?
  2. jimbo
    jimbo Plumber
    One of the things that happened is that the dip tube just broke off at the top, leaving the tube loose in the tank, and all the incoming cold right at the top. SO this could be your problem, and the time frame is about right. If you go to the manufacturer web site, they should be able to confirm by serial number if your tank was affected.
  4. Gary Swart
    Sep 1, 2004
    Yakima WA
    OK, I've Googled the hell out of the dip tube subject, and I am totally convinced that it is the dip tube at fault. The tank was made in 1996 which was when the bad tubes were used. It lasted this long, so I have no complaints on that. In looking at the cold water intake, I can not determine just how the the dip tube is removed and replaced. All that I can see without taking anything apart is the nipple that goes into the top of the tank. I could use a little insight on the R&R before I just plunge blindly into the job. What do I see when the nipple is removed and how do I get the old piece out? I've installed several heaters, but never had to deal with a dip tube.
  5. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    you dont get it out
    when the dip tube is broke off in the tank...
    thats where I call it a day and tell the customer
    that it would be in their best interest
    to get a new water heater becasue you simply
    CANNOT get it completely out of the heater....
    in fact, its gonna sit in the tank and break down over
    a period of time and could eventually clog up all the faucets
    and appliances in the home...
    you can put another one in the heater....and that will work
    but the old one is like a ticking time bomb and eventually
    will cause them greif...
    thats what that law suit was all about and it ended in 01.
    so it jsut depends on the customer .....
  6. Gary Swart
    Sep 1, 2004
    Yakima WA
    Yeah, I know I can't get the broken piece out, but I'll deal with the clogging problems as they happen. So far there hasn't been a trace of debris, but I know that's subject to change at anytime. I can easily drain the tank frequently so maybe that will forestall the problem. Thanks of the advice, I know you're right, but I'm just going to stretch the life of the tank as long as possible. It's in an easy to access area so changing it will not be a problem when I absolutely have to. I am fortunate that I live in an area where the water is very high quality, so heaters don't fail too often, this dip tube problem aside.
  7. Peevee
    Peevee Member
    Oct 24, 2006
    Milan, Tennessee
    The ones I've seen have already disintegrated. You should be able to stick your pinky finger in the cold water inlet and sometimes there is only a ring left of the old dip tube. You can pick up another one at a plumbing store.
  8. Rancher
    Rancher Guest
    Gary,
    The dip tube slides down thru the cold water fitting, it's about 5/8" id, with a flare on the top of it to keep it from going in too far. Just remove the cold water nipple and you should be able to feel it, they're not easy to remove... and how are you going to get the new one in? I wouldn't worry about the old one breaking down in the heater, after all it's been there for over 10 years now, and it's pvc so if it breaks down in water then we're going to have a massive class action suit against the pvc mfg's.
    Good Luck, sounds like it's more trouble than it's worth.
    Rancher
  9. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Or just for kicks take a piece of 1/2" copper and cut it so it stays off the bottom about 16". Use pliers or anything to make kind of a flair. Just wide enough to keep it into that old nipple or on top of it's threads and put it back together.
    Easier to do if there is a union there.
  10. Gary Swart
    Sep 1, 2004
    Yakima WA
    Well, it's done! I got a new dip tube and went to work. There was just a ring left on the top. Fished it out, took a 3/4" wire fitting cleaner brush and cleaned off the gunk. There was enough flex in the new tube to put it in without draining the tank and tipping it. Had to cut about 5" off the tube, but after that it was simple. I'll give it the shower test this evening, but that has to have cured the problem. If I get start getting pieces of the old tube in my fixtures, I'll drain and flush the tank and lines. I have a 3/4" ball valve on the tank drain and the tank sets over a concrete basin with a floor drain so draining is quick and easy. Thanks to all who offer advice, even if I didn't use all of it! Today has been a learning day for me.
    t
Similar Threads: tube question
Plumbing Forum, Professional & DIY Advice Question about water tube Dec 5, 2015
Plumbing Forum, Professional & DIY Advice Water Heater Discharge Tube Question Oct 12, 2014
Plumbing Forum, Professional & DIY Advice Moen Stop Tube Question Jun 25, 2014
Plumbing Forum, Professional & DIY Advice Water Line Diagram & Terry Love question on YOUTUBE! Oct 9, 2012
Plumbing Forum, Professional & DIY Advice Quick PVC tube/kitchen plumbing question May 29, 2008
