LLigetfa
DIYer, not in the trades
What disturbs me is the long horizontal sections you keep drawing. You say the other side of the wall is exterior brick so is not the vertical DWV just inside the wall and not far away as depicted?
How is that vertical DWV supported? Could it be cut below in the crawlspace and the hole in wall under the counter elongated so as to drop the pipe the desired amount? If the top goes straight up it would just protrude a little less through the roof.
Are you saying where it disappears into the wall that it doesn't go vertical right away, that there is 3 more feet of horizontal before it does?Yeah, not to scale. That horizontal pipe is 3 feet.
I already had my sink and disposal before he even started the job which he saw, so it's completely on him.
To be clear, the contractor hasn't left yet (haven't paid him the other 50%) and I called him out on it. He wants to work it out and we are exploring options. I'm posting here because I trust you guys a lot more than him and seeing if there are any other viable options. Cutting into the wall and cabinet, disturbing insulation, framing, etc. is what I'm trying to avoid IF I CAN. We very well may just go into the wall and do it right but just thinking out loud here. I appreciate everyone chiming in, I really do. You guys are awesome.
Is there an inspection / inspector involved?
Was that intended as an offset to get around a window or other obstacle?Yes once the drain goes into the wall, it goes horizontal for 3 feet before tapping into the wall. Was this way originally before we got to the house.
Could you push down a new pipe from the attic directly in line with the stud bay and just abandon the old one?
I'm considering this option as well. Remove disposal (don't really use it anyways) plus shallow baskets. Does the dishwasher Y have to be above the drain line since the drain line is attached at the way top of cabinet?
My inspector would never approve an offset like that. Even if the OP got rid of the garburator and raised the trap, would it pass inspection with the existing right-angle offset?Did that plumber actually install the offset pipe in the wall AND its connection into the vertical pipe?
quote; I've read this ten times and I still don't get it.
In a later posting, you indicate that there is a 3' offset in the wall. That can negate using it as a vent because it would have "backwards" slope as far as a vent is concerned, and could NOT be connected in such a way that any water in it could drain out. An AAV would get him off the hook cheaply, but would not be an ideal situation. Did that plumber actually install the offset pipe in the wall AND its connection into the vertical pipe?
A vent cannot go horizontal until it is 6 inches above the flood level (rim) of the sink.
