Delta single handle faucet hard to turn after parts replacement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Norwegianwood, Jul 1, 2010.
  1. Norwegianwood
    Norwegianwood New Member
    Jul 1, 2010
    Virginia
    I recently replaced the cam and packing, ball and seats/springs in my 10 year old single handle Delta bathroom faucet. It does not leak from the spout anymore but it is much harder to turn and operate the handle. I have played with the adjusting ring. Any ideas? Thanks.
  2. hj
    You could have an "aftermarket" ball which was not made to the company's specifications.
  4. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    Put some silicone grease on the bottom of the cam washer where it rubs against the ball.
  5. Norwegianwood
    Jul 1, 2010
    Virginia
    Tom- any specific brand you recommend? Thanks.
  6. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    Like HJ said - did you use a genuine Delta replacement part? Most of the repair kits in the big box stores are not; it does make a difference.
  7. hj
    IF you used the correct parts, you do NOT need to lubricate the seal. In fact, if you got the newest kit, it should have had the new one piece seal, rather than the rubber washer and plastic cam.
  8. Norwegianwood
    Jul 1, 2010
    Virginia
    Tom,
    The silicone grease did the trick! Thanks all for your help.
    'Wood
Similar Threads: Delta single
Plumbing Forum, Professional & DIY Advice delta single handle faucet drip Jan 3, 2016
Plumbing Forum, Professional & DIY Advice Delta single handle kitchen sink sprayer diverter valve Mar 1, 2015
Plumbing Forum, Professional & DIY Advice Is Delta ball the only single lever faucet mixing valve with multiple manufacturers? Mar 26, 2013
Plumbing Forum, Professional & DIY Advice Old Delta single lever shower faucet issue Aug 14, 2012
Plumbing Forum, Professional & DIY Advice Delta Single Handle Pull-out leaking?? Jul 6, 2011
