Delta R10000-UNBXHF Multichoice Universal Shower Only Valve Body
Discussion in 'Shower & Bathtub Forum & Blog' started by themp, Feb 1, 2013.
  1. themp
    themp Member
    Feb 5, 2008
    Raleigh, North Carolina
    Going to attempt to install this myself after the tile guy does the demo. I looked at the instructions tonight and have these question. Did search the forums first, but had over 200 hits. So, here goes...
    1.) There is a metal black filter screen in the brass body. I am confused on what this does as the instructions say to remove this when done and leave it in when you solder. It also says that to much heat can damage it while soldering. I want to just remove it while soldering. Why would it tell me to leave it in while soldering? And what does it do while flushing, are there internal passages I cannot see? Because it looks like the filter screen just runs to the 1/2 inch shower head pipe.
    Here are the instructions that are confusing me:
    "Remove bonnet (1) and test cap (2) before soldering. Leave screen (3) installed. Warning: Avoid soldering at high temperature. Exposure to high temperatures may damage screen."
    "After flushing remove filter screen (5) and reinstall cap, bonnet and cover."
    2.) It came with this reusable test plug. This plug will not fit in with the filter screen in place and if I put in the plug then the filter screen, the filter screen will not seat. Here is what the instructions say for this plug. "Used to plug one inlet side (Hot or Cold) to prevent cross flow when checking for leaks before the cartridge is installed. Insert into the inlet, place test cap and use the bonnet to secure in place." I do not understand this cross flow problem and why I need to stop it for leak testing.
    3.) In actually testing for leaks, do I need some kind of valve on the shower head pipe to let the air out? Or will the water pressure be enough to get the water to the end of the shower head pipe?
    Thanks, Tom
    [​IMG]
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Crossover would happen during the test but if you don't use water during the test it matters not. Most often, the system may be pressurized longer than just the test, so unless you get the body with integral shutoffs, you will want the plug.
    It is not necessary for the water to reach the top. If you have a leak, the air will all leak out and you will see the water exit. If there is no leak, it is moot.
  4. jadnashua
    During construction, it's not uncommon to get crud in the valve. When it comes time to install the cartridge, it is very important to flush it first. If you know how to solder, you won't overheat it enough to damage the filter screen, but you could damage the rubber parts of the cartridge if it were installed.
    Until you install the cartridge, when the water is on, there's a direct path from the hot to the cold, and depending on how your pipes are laid out, you usually will get lukewarm water everywhere because of it. This is why they provide a plug. Make sure to brace the valve body well and get it at the proper depth so the trim fits like you want. There's a min/max, and anywhere in between the trim will fit, but you may want to mock up the wall thickness to get it where YOU want it aesthetically.
  5. themp
    themp Member
    Feb 5, 2008
    Ah, now I see about the plug for the crossover. Stops crossover while the tile guy finishes his work and we use water in the rest of the house. Thanks.
    Still confused on the filter screen, what is it for and I assume it is removed when the plug is in place and is not needed when the actual valve is installed.
    Tom
  6. IC31
    IC31 New Member
    Mar 13, 2013
    retired project manager,
    Upstate NY
    Delta multichoice tub valve installation
    First post - just found this forum and wish I had earlier!!
    I'm about to install a Delta multichoice 10000 series valve using their less then great set of instructions and on a brand new Praxxis tub and surround. I have the supplied plaster guard as well as the two optional thin wall plates. This Praxxis tub surround, for no better words is not a quality fiberglass/gel coated assembly, being not much thicker then the gel coat in places. I'm very reluctant to try to whittle a hole with my jig saw the size of that plaster guard on that flimsy and brittle fiberglass.
    Now, this is what I'm thinking and would appreciate some discussion on this. I prefer using a hole saw approximately the same size as the snout of the valve, say 2.5" - 3", then using one of the thin wall plates as a template drilling holes to access the various attaching screws and the trim screws. This in turn will then move the valve away from the outer face of the surround, guesstimating at possibly as much as 3/8". The required 'stringer' will be installed once the valve is situated I am not using the 'stops' version valve as being one more unneeded and potential headache.
    Second question or whatever - is there a rule of thumb for placement of tub and shower spouts? The tub spout has to be at least 8" below, mine is set up at 12 and there is a flood level minimum - but any actual height suggestions for the valve and shower outlet, knowing that I'm 6'4" tall with a 5'7" wife.
    Thanks for looking and your comments:D
  7. jadnashua
    I used a handheld on a sliding bar to allow easy adjustment for various people. Securing that reliably to a thin surround might be problematic, though.
  8. mikekenmore
    mikekenmore Member
    Aug 13, 2015
    Kenmore, Washington
    tom,
    did you remove the filter screen to do your soldering?
    does one actually need the test plug? i see in my kit it's listed as being sold separately. i'd prefer not to buy one if it's not absolutely necessary.
  9. jadnashua
    You can plug the end of the shower riser, you don't need to plug it at the valve itself. In either case, though, you'd still need a cap, but maybe a different one depending on where you needed to plug it.
    You really don't want to get solder into the valve, and the filter screen can help prevent dropping a solder blob or crud into the guts. IOW, follow the instructions and leave the filter screen in there during install.
  10. mikekenmore
    mikekenmore Member
    Aug 13, 2015
    Kenmore, Washington
    got it. thanks.
    so, i have the valve and all other shower/tub pipes soldered in. did a leak test. things are fine. however, after opening hot/cold stops, i noticed that my cold line started to get pretty warm. the cold line is shared with a toilet on the opposite wall. how far the warm water goes, i'm not sure. i would hate to be heating all my cold water lines! is this common? did i do something wrong? is it just a matter of adjusting the ratio of hot to cold with the stops?
  11. jadnashua
    If the cartridge is not in the rough-in valve, it's normal, and you should use the plug that comes with it to stop the cross-over. The cap just keeps it from leaking out the front, but without a cartridge in there, there's a direct path between the hot and cold water supply lines, and they will mix. Once the cartridge is in, it won't be an issue.
  12. mikekenmore
    mikekenmore Member
    Aug 13, 2015
    Kenmore, Washington
    do you have a picture of the cartridge? i don't have anything else in the valve box. the only loose parts that came with the valve was were the two stops and two nuts for the stops. on the valve were the plastic cover, gasket, and brass cap along with the filter screen.
  13. jadnashua
Similar Threads: Delta R10000-UNBXHF
Shower & Bathtub Forum & Blog Delta R10000-UNBXHF CPVC Sizing May 20, 2014
Shower & Bathtub Forum & Blog Delta Delex, identifying bathroom faucet brand and cartridge Tuesday at 1:16 PM
Shower & Bathtub Forum & Blog Old delta shower valve not working Feb 25, 2017
Shower & Bathtub Forum & Blog Delta rain can shower head install Feb 19, 2017
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Feb 14, 2017
