Delta Monitor 1700 Valve question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by elgato, Jan 24, 2007.
  1. elgato
    elgato Member
    Jan 20, 2007
    Phoenix, AZ
    Delta now ships the universal valve for the Monitor 1700 series without the cartridge. I does come with a cap. Can this rough-in valve be installed without the cartridge and trim and water pressure restored? The cap does not block the hot and cold inlets internally so water could flow together.
    Thank You
  2. hj
    cap
    That is the reason for the cap, so you can wait until after tiling to install the cartridge.
  4. prashster
    prashster New Member
    Dec 7, 2005
    Besides the cap, there are 2 screw valves on the hot and cold supplies that you can use to turn off supply.
  5. hj
    valves
    Not all valves, in fact very few, have the integral stops.
  6. prashster
    Dec 7, 2005
    I just installed a new Delta 1700 universal valve and the version that was shipped to me had those stops.
Similar Threads: Delta Monitor
Plumbing Forum, Professional & DIY Advice Unfamiliar Delta Monitor Cartridge Oct 2, 2016
Plumbing Forum, Professional & DIY Advice Delta Monitor Shower handle removal Oct 30, 2011
Plumbing Forum, Professional & DIY Advice New Delta monitor, no water Jan 8, 2009
Plumbing Forum, Professional & DIY Advice Delta Monitor Valves May 12, 2006
Plumbing Forum, Professional & DIY Advice Help identify Delta faucet Jan 29, 2017
