Delta faucet keeps running after shut off
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by trw888, Feb 4, 2014.
  1. trw888
    trw888 Member
    Sep 23, 2009
    Tucson
    4 year old Delta two-handle kitchen faucet model #21902-LF,
    Original problem: Water kept running for severalseconds after we turned it off. It slows to a trickle and then to a severe and the eventually stops. This happened suddenly and did it for both handles. Called Delta and was told the problem was the stem unit assemblies and they sent me two new ones.
    Second round of problems: After I replaced them, it made no difference on the cold side. The water kept running for a few seconds after shutting it off. And the hot water stayed running no matter what. It didn’t matter if the handle was turned off or on, the only way to shut it off with at the valve underneath the sink. After messing with it for nearly two hours, I replaced the new assembly with the old one and that problem went away.
    But now I’m back to the original problem.
    Help!
  2. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
  4. trw888
    trw888 Member
    Sep 23, 2009
    Tucson
    Thank you Smooky. Yes, the seats and springs were part of the stem assembly units Delta sent me.
  5. hj
    Then your problem is illogical, assuming ALL the parts were installed properly, because one those THREE pieces are replaced there is no reason for the faucet to leak, much less "run for a few minutes". Also, are you sure the hot unit was not installed backwards so that you would have had to turn it ON in order to stop the flow, (a common mistake for DIYers who do not know it can be installed two different ways)?
  6. trw888
    trw888 Member
    Sep 23, 2009
    Tucson
    Thanks HJ. I know the assemblies need to installed in a certain way and made sure to install them exactly like the old ones. I also double checked against the diagram. And after that didn't fix the problem, I installed them in the opposite direction just to make sure.
    As for the hot water, it ran continuously no matter if the handle was turned on or off. I re-installed the old assembly exactly the new assembly, which was installed exactly like the assembly when it came from the factory and the running continuously problem went away. I've also double checked the part # to make sure Delta sent me the right parts.
Similar Threads: Delta faucet
Plumbing Forum, Professional & DIY Advice Help identify Delta faucet Jan 29, 2017
Plumbing Forum, Professional & DIY Advice Delta kitchen faucet sprayer diverter clip - need tips please! Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Delta shower faucet style Dec 27, 2016
Plumbing Forum, Professional & DIY Advice Replaced Delta 2 handle faucet cartridges now there is small leak from valve stem Oct 30, 2016
Plumbing Forum, Professional & DIY Advice Delta Faucet Question (is it broken?) May 23, 2016
