Dedicated Plasma TV circuit
Discussion in 'Electrical Forum discussion & Blog' started by Smith333, Jun 6, 2008.
  1. Smith333
    Smith333 Member
    Sep 5, 2006
    Wisconsin
    I want to add a dedicated circuit for a new plasma TV and associated electronics. The breaker will be located in a 100 amp subpanel. Should I go with a 15 amp or 20 amp circuit - Is more always better? Also, should I use a normal circuit breaker or would something like a ground fault type provide more protection?
  2. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    In my stupid opinion, a 15 amp circuit will suffice. The only thing I would add is some type of surge protection for the tv, along with surge protection for the entire house.
  4. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    I'd go with 20. I did in my house.
    15 will suffice but a 20 amp circuit wil not cost much more......and you get 5 extra amps ;)
  5. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    a whole whopping 600 watts... Pull a 14-3 if you really want to impress the chicks.... :D
  6. jadnashua
    If you are a real purist, you'll get a nice true sine-wave ups and run the electronics off of it. In this type, it doesn't switch to the ups when prime power is lost, it always runs off the ups and the batteries. Prime power only keep the batteries charged. Most UPS devices, at least on the low end, perform some filtering, but only switch to the batteries and the oscilator output (to get the pseudo a/c output) when it senses the voltage dropping.
    If you don't go that way, it is nice if you get a high quality power line conditioner/surge suppressor.
  7. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    In the past I have lived in homes which had 15 amp circuits everywhere and I had frequent problems with breakers tripping.
    When I got my own home, I rewired *all* my 120V circuits to be 20 amps and have had no problems with breakers tripping. I can plug in a vacuum or space heater and not worry about tripping the breaker.
    The rule is: If you are wiring another person's home and want more profit, then 15 amp circuits. If you are wiring you own home, then 20 amp circuits!
    Also you can get cheap 50 cent outlets/switches (loose in a bin) or "commercial grade" outlets/switches (each in own box) for around $3.00 each which are much better in quality. I have all commercial grade outlets switches in my home.
    For some electric panels you can get a "whole house surge suppressor". These snap in like a double breaker. I have this on my main service panel. (Be sure you have a good ground on your main panel. Best is cold water pipe ground and 2 ground rods placed 6 ft. apart. If plastic water pipe, then just two ground rods.) There are also "add on" whole house surge suppressors.
    I also have surge protectors at each place I plug in something electronic. The best surge protectors in my opinion are those which offer the best "warranty" should your equipment be damaged (like $50,000.00 coverage). My thinking is they would not offer such a warranty unless they were darn sure their product was so good no one would ever need to collect!
    So far as a GFI, these are designed to protect someone from being electrocuited by an appliance with faulty wiring. These are best in a bathroom/kitchen or outside where there can be a wet environment.
  8. Billy_Bob
    Apr 2, 2008
    P.S. You might find better quality and more selection for plug-in surge suppressors at an office supply or computer store than at a hardware store...
  9. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    This may be YOUR rule, but it is not true in the real world.
    Sorry, but I consider this rule B-S.
  10. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    i agree, #12 is a complete waste of money and time.
  11. Speedy Petey
    Jun 16, 2007
    NY State, USA
    In some cases, such as BR receptacles and most residential lighting. :)
  12. Billy_Bob
    Apr 2, 2008
    Actually when I was rewiring my house, I thought about my running 12 ga. and 20 amps to the bedroom as maybe not being necessary. But I did it anyway...
    Well a few years later, energy rates skyrocketed. I was able to use a space heater to heat just my bedroom at night (instead of the whole house) and save on my heating bill. Then in the summer same thing with a window air conditioner in the bedroom.
    Anyway I was glad I had run the 20 amp circuit. And this has been my life long experience with electrical wiring. Frequently need more outlets than what was installed, frequently need more amperage on the outlets which were installed, and frequently need more spaces in the breaker panel than the panel has available.
    Anyway I like to "over engineer" everything electrical for future needs.
  13. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Glad it worked out for you...
  14. brownizs
    brownizs In the Trades
    Feb 9, 2006
    Springfield, IL
    A 15amp is all that is needed for a Dedicated Electronics Circuit. As for isolating noise & other damaging baddies in the Electrical Circuit, it depends on how much disposable income that you have.
    Personally, I have my Plasma on the same circuit as the other Electrical outlets (along with the overhead light & hallway outlet & light), and no problems. Of course, I used a good Surge/Noise Suppressor on the Electronics.
  15. brownizs
    Feb 9, 2006
    Springfield, IL
    I am guessing that you are not a Certified Electrician, but then again with the comment of changing the 15amps to 20amps pretty much sold that, along with the "Use a snap in Whole house Surge".
  16. brownizs
    Feb 9, 2006
    Springfield, IL
    The ones at Hardware Stores are just as good as the ones in Office Supply & Computer Stores, just not as overpriced.
  17. kd
    kd New Member
    Dec 11, 2006
    The problem with using #12 on lighting circuits is that you will probably cram too many wires in a box which is a Code violation. Some AHJs require all receptacles to be on 20 amp circuits.
  18. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Do these some AHJs have a written adopted code to back it up??? :rolleyes:
  19. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    You'll find the best selection and price on the Web. I use APC exclusively, and almost always buy their factory-refurb units, which carry the same warranty as new.
  20. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Same thing can easily happen on receptacle circuits if you use shallow boxes.
  21. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Surge Protection
    The usual plug-in device for the Square D QO panel is QO2175SB. The warranty for equipment protection excludes A/V and computer equipment.
    The Full Protection unit is the SDSB1175C. Its warranty protection includes computer and A/V equipment. I don't have a price for it but it is probably in the multi-$100s range.
    http://ecatalog.squared.com/pubs/El...e Devices/OEM Panel Mount TVSS/6671CT9701.pdf
    Warranties are described in the catalog from the link.
Similar Threads: Dedicated Plasma
Electrical Forum discussion & Blog Dedicated circuit kitchen rule for wet bar? Jul 4, 2016
Electrical Forum discussion & Blog Dedicated outlet for freezer in laundry room = AFCI? Jun 30, 2016
Electrical Forum discussion & Blog Dedicated electrical box (for hot water tank) needs replacing: what to expect? Dec 14, 2015
Electrical Forum discussion & Blog Tankless water heater ... dedicated to washing machine Jul 11, 2015
Electrical Forum discussion & Blog AFCI breaker (in Wisconsin) needed for dedicated light circuit? Jul 30, 2014
