Deco Lav vanity sink drain issue....?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Antalamo, Jun 6, 2011.
  1. Antalamo
    Antalamo New Member
    Mar 19, 2011
    San Diego, CA
    I installed 2 Deco Lav vanity sinks. I finished it off with 2 Hansgrohe widespread faucets that included the drain assembly. The problem I have is the drain outlet flange is not sealing at all. Hansgrohe provides a gasket and does not require plumbers putty.
    The only thing I think could be an issue is the drain hole has a slight contour around the edge possibly causing the leak. My question is if anybody has had problems with Dec Lav and would it be recommended to use their drain assembly. I figured Hansgrohe to have a higher end assembly but it does not work in this case.
    PS: I used plumbers putty in place of the gasket and it leaked worse. Maybe I need a thicker gasket around the drain outlet flange???:confused:
  2. hj
    In another location you say the "contour is at the rear" implying an assymetric design, but here you say it is "around the edge" implying symmetry, which would be a completely different issue than a "tear drop" shaped recess. WE would have to see the drain hole to determine WHY you are having the problem, since I have not had that problem even though I ALWAYS use plumber's putty, or the supplied gasket.
Similar Threads: Deco vanity
Plumbing Forum, Professional & DIY Advice hot water heaters need to decommission chimney Aug 20, 2014
Plumbing Forum, Professional & DIY Advice Outdoor patio sump with decorative grate Apr 1, 2013
Plumbing Forum, Professional & DIY Advice Quality of decorative supply lines and drain/overflow for clawfoot tubs? Dec 25, 2008
Plumbing Forum, Professional & DIY Advice Decolav and Grohe Install Help Feb 19, 2005
Plumbing Forum, Professional & DIY Advice Back-to-back vanity DWV Oct 11, 2016
