Culligan Ironcleer System failure
Discussion in 'Water Softener Forum, Questions and Answers' started by Eco1111, Sep 11, 2012.
  1. Eco1111
    Eco1111 New Member
    Sep 11, 2012
    Clifford, Ontario
    My Ironcleer system recently died - apparently it the compressor died. I have only had the system for 5 years, so I have a couple questions:
    1) How is the stress on the system related to the work that the compressor does? ie. is there additional 'work' that the compressor does per cycle if the iron in the water is higher?
    2) What is the average life span of a compressor?
    3) Given that I paid $3500 for this unit, that works out to $700/year to remove iron from my water. Is this a reasonable cost?
    Thanks and Regards,
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Obviously the more iron and the more water you use, the more the compressor runs but you should get more than 5 years out of it. Unfortunately, I suspect it's out of warranty and to make things worse, you can probably only get another one from Culligan but maybe you can go with some other makers pump.
  4. ditttohead
    Jan 9, 2012
    Ontario California
    Cost is relative. You may look to replace it with a different design in the future. There are several reputable companies that sell Iron removal units. I prefer the ultra simple Pyrolox type of units that simply backwash every couple of days. Air injection can be added for a minimal cost. Other common and simple designs are the chlorine injection/contact tank/ backwash GAC systems. Chlorine can be injected by a pellet design, water pump, or electric pump. All three are good and each has their advantages and disadvantages. Iron removal can be tricky, do you have a recent water test so we can make a better recommendation?
  5. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Is the compressor leaking water or not putting out air?
Similar Threads: Culligan Ironcleer
Water Softener Forum, Questions and Answers Culligan Medalist Series Model WG844 Tuesday at 7:12 AM
Water Softener Forum, Questions and Answers Culligan Mark 89 always draining Jan 7, 2017
Water Softener Forum, Questions and Answers Replacing Culligan Super S Jul 12, 2016
Water Softener Forum, Questions and Answers Culligan Super S Won't Pull Bleach Jul 7, 2016
Water Softener Forum, Questions and Answers Culligan Super S Apr 9, 2016
