"cricket" sound after turning off shower
Discussion in 'Shower & Bathtub Forum & Blog' started by mav91, Aug 17, 2009.
  1. mav91
    mav91 New Member
    Aug 17, 2009
    I've got a faucet (Delta I think) on my tub, one of those big plastic ball kinds that has the two washers-and-springs behind the ball (lift up to turn water on, turn left or right to adjust temperature). That part works fine, no leaks after moving the ball all the way down.
    Below that is a rod that is the shower diverter. The shower head is a one of those basic shower massage head with a rubber hose.
    So...I've noticed sometimes after I shower, it'll be quiet, but then a few minutes or later: for a few hours or a day I'll get a "cricket" off-and-on sound that maybe sounds like it's coming out of the plumbing in that bathroom by the tub. The faucet/spigot itself doesn't appear to leak at all once I put the ball all the way down.
    Is this little off-and-on "cricket" noise a pressure thing after I shut if off? If I play with the diverter a little--moving the knob in and out--will it relieve pressure? The house is up for sale, so I'd rather not spend any money to fix it. Unless this like, totally, a huge deal. It doesn't do it all the tme, just sometimes.
  2. mav91
    mav91 New Member
    Aug 17, 2009
    Got home from work today, seems to have stopped. Wierd.
  4. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Maybe you actually had a cricket stuck in there and now it's dead. [​IMG]
  5. hj
    Unless the diverter rod pops out as soon as you turn off the water, the cricket sound could be it popping out later. If so, it is sticking and should be replaced. Otherwise it could break, and when that happens the rod is ejected from the faucet and often hits you in a very sensitive part of your body.
Similar Threads: cricket sound
Shower & Bathtub Forum & Blog Sound of running water after shower faucet is turned off? Jan 11, 2016
Shower & Bathtub Forum & Blog My shower head sounds like a bird is stuck in it! Jan 30, 2014
Shower & Bathtub Forum & Blog Tyroc Subflooring - Sound, Moisture and Uncoupling flooring prep Dec 10, 2013
Shower & Bathtub Forum & Blog "Running Water Sound" coming from behind the walls - What could be the cause? Jul 13, 2012
Shower & Bathtub Forum & Blog Jacuzzi Tub Access Panel - Building, Access and Sound Proofing May 19, 2012
