Crack in Hung Sewer
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ttharp, Oct 25, 2009.
  1. ttharp
    ttharp New Member
    Oct 25, 2009
    Virginia, USA
    I have a crack in my PVC drain line just inside where the hung sewer enters the cinder block wall. Unfortunately, the line runs under my deck and would be a bear to access from outside.
    My thinking is to use an internal pipe cutter and make the replacement from the inside (not sure if I would try this myself or not ...). Are there other options?
    I was also thinking I would add a flexible coupling above the fitting to reduce any future stress on the joint.
    Only good news is that the exterior has good drainage (never had any water in the basement) and not much risk in that direction.
    Any advice appreciated,
    Tom
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    If you end up using a clamp on coupling, you must use a banded coupler, not a plain neoprene with just 2 clamps. As for the best way to do the actual repair, I'll let others comment on that.
Similar Threads: Crack Hung
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cracked elbow below closet flange Dec 24, 2016
Plumbing Forum, Professional & DIY Advice Surface Rust / Cracking at Kitchen Sink hole - Should I repair it or ignore it? Oct 22, 2016
Plumbing Forum, Professional & DIY Advice Cracking stopcocks Mar 8, 2016
Plumbing Forum, Professional & DIY Advice Cracked drain pipe under shower concrete slab Sep 4, 2015
