CPVC Metal Ball Valve & Expansion Tank
dauber man
Los Angeles
I’m planning on installing a metal shut off valve right after the water meter (see photo). A few questions…
1) I’m planning on using a metal ball valve with cpvc connectors (Sioux chief makes one). Is it as simple as cutting and solvent welding on the valve?
https://www.supplyhouse.com/Sioux-C...etalHead-Full-Port-Brass-Ball-Valve-Lead-Free
2) Will cutting the pipe affect the expansion tank at all? Will it need any sort of adjustment afterwards?
3) I was thinking of adding more pipe (in the shape of a U) to place the shut off valve at a lower level for easier access.. Will adding this cause any issues with water flow?
Thank you for any assistance here…
dauber man
Los Angeles
I'm also considering adding the shut off valves to the hot and water lines separately (see photo) as that small piece of pipe after the water meter appears very brittle (although the house is only 1 year old) and may be risky considering the weight of the water meter.
Is this a better option?
Sylvan
Still learning
New York
" I was thinking of adding more pipe (in the shape of a U) to place the shut off valve at a lower level for easier access.. Will adding this cause any issues with water flow?"
Adding any pipe or fitting will cause some friction losses
Is there not a shut off valve at the incoming side at meter?
That would be a good place , a valve on hot water side as noted is good but you want a valve at incoming side of water heater, I never have built or seen a new house with no shut off on cold to water heater and on the hot side its very uncommon (but can be handy)
1 year old CPVC shouldn't be brittle. I haven't seen CPVC going in on homes here but not up to date on trends. I did a few hundred in the 90s
dauber man
Los Angeles
There’s a plastic ball shut off before the meter but I’m afraid it will eventually freeze up. I’m trying to out a metal shut off in just in case.
this CPVC is making me nervous.. how concerned should I be about it’s durability?
also do I have to do anything with the expansion tank if I cut open the line?
thanks
I cant say how worried you should be CPVC does get a lot of bad talk my moms house is in Florida I think built around 97 never had a problem. I don't think CPVC is much of a selling point copper has its problems in areas of SO Cal as well PEX is it the greatest ? I don't necessarily think so. Galvie in some places with good water lasts 60 plus years .
It is what it is You've got CPVC
