Mike Richardson
Hi Guys,
Had a 1/2" CPVC shutoff go bad in stud wall to outside faucet. It was sandwiched between 2 studs 7" apart. I replaced the shutoff but had to bring in an 8" piece from the adjacent stud opening. My predicament is that I don't know the correct way to join the two pieces. There is not enough flex to simply bend in a straight union. I found several ways to connect the 2 ends: 1.) I could use an inline coupler but I really don't want to have a coupler with gaskets behind my wall. 2.) Using 4-90 degree elbows and a short (3") piece to essentially make a "U" to connect the 2 pipes. 3.) Dremel out an ordinary coupler and then try to slide it down after applying the glue. None of the above seems like the professional method. Surely people run into this problem all the time. "Connecting 2 cpvc pipes (not flexible) in a stud wall." No option to go downline and run a long piece in...no room. Any assistance would be greatly appreciated. Thanks in advance... ~mike
