Copper water supply line
Cscjjd
Louisiana
Hello,
I will be replacing part of my home's underground water supply line and I have a few questions...
1. Will I be able to sweat a new fitting onto the 3/4" copper going into the home using a propane torch (to replace the compression coupling in the photo below) ? I am wondering if the soil will be such a heat sink that I will not be able to heat the pipe sufficiently with a propane torch?
2. Would a brass compression fitting be a suitable option instead of a sweated fitting?
3. I would like to replace the 3 year old cutoff valve that already has corrosion issues. Would a full port PVC ball valve be OK?
John Gayewski
Iowa
You can't solder underground copper. Not because it won't solder, it's because a solder joint isnt a weld or mechanical joint. Brazing is a type of weld.
You need tio flare it and use flare fittings. These are a bit specialized. Call a plumber to get you up out of the ground.
Cscjjd
Louisiana
I am not sure I used the correct term. This part of the supply line is under a concrete meter box which is embedded in the concrete driveway. Is this still considered underground? Thanks.
John Gayewski
Iowa
Yeah. Ground movement is why a solder joint isnt kosher.
Still need flaring tools or brazing rod and flux for dissimilar metals.
Plant.One
Just here for the Beer.
oakland county, MI
If I understand correctly, SharkBite fittings would only be OK if I decide to use PEX for the replacement pipe?
push to connect fittings (sharkbite is a brand name) are good for copper or pex.
Could you please expand on this - what is the drawback to this type of valve?
on my expierence - those valves dont age well at standard room temps. they bind up, and in general fail over time, significantly sooner than a brass valve will anyway. just install a good quarter turn valve in there.
pex with metal valve is a much more suitable replacement, and will be much simpler to install/repair due to its flexibility and your confined space you're working in IMHO
Mr tee
Montana
I wouldn't use a PVC ball valve, and I wouldn't use a brass one unless it had a stainless steel handle - the plated steel ones corrode and can fail in moist locations.
Cscjjd
Louisiana
Thanks Mr. tee - I think that's what happening with the valve that's in there now.
