Copper to PEX adapters
Hornnumb2
Texas
Is one of these better than the other? I have been using the brass ones but the cost difference quite significant. Thanks Michael
Water Pro
syracuse
you don't need to sweat fittings. sharkbites or john guest fittings will work fine, with the added benefit they're removable
Hornnumb2
Texas
Just like sweat fittings better, just don’t have the faith in sharkbites.
Water Pro
syracuse
If installed correctly they are bulletproof, as are john guest. I've installed thousands without a single failure. I would understand however if cost is an issue. I would think either would be fine. SS pex bands, however, are far superior to copper crush bands, which lend themselves to the occasional leak
