Convert standpipe into sink drain?
nestor87
Massachusetts
Hi -- I've been searching and reading for a couple days and couldn't find a clear answer to this:
As in many posts I've read, I'm trying to add a utility sink in my basement. I'm hoping to use the 2" drain that is now serving as a standpipe for the washer as the drain for the sink. I've seen many threads where people try to then add a new standpipe to the same line, but I'm happy to simply hook the washer hose over the edge of the new sink. Given that I'm not adding a second fixture -- just swapping out a standpipe drain for a sink drain -- can I just saw off the old p-trap, extend the horizontal pipe a few feet, and add a new p-trap below the new sink?
Edit: Photo of the standpipe and trap is attached -- the sink would be where the washer is now, so I'd only need to move the trap over and out a couple feet.
Montreal, Canada
Thanks for joining and posting the forums.
With many new members looking for advice and answers, be reminded that good photos and illustrations always invite an audience that can give faster replies that are less generalized and more suited to your exact needs.
Try to provide at least two photos. Include a closeup of the attention area so we can identify fine details, and include one zoomed out so we can see the rest of the room and things nearby, adjacent areas, floors underneath. Use a black marker to write on blue painter's tape or bright colored Post-It's to mark areas of interest, there is no need to modify your photos with fancy text overlays. Take as many photos as you can, choose the best ones that are clear.
Do include diagrams for plumbing and supply line projects. A scan or photo of a hand drawn illustration done quick on paper is usually easier for most to create than trying to make one in a computer app. We don't need architect schematics, just something simple to help us understand your project.
Make sure your location is in your member profile, this tells us where you are so other members here with experience in your area may give you specific recommendations that may apply to your seasonal weather conditions and state code.
While waiting for replies, please make some effort and take the opportunity to search these forums extensively, it is likely that many in the past had your similar issue, and you may find solved solutions quicker than the many days it can sometimes take for you to get answers you want.
As you solve your problem to finish, kindly please follow up on this same thread you created and update your progress, so future members with your same problem can see that this may also be used to help them.
Cacher_Chick
Test, Don't Guess!
If the existing standpipe is properly vented, it would work, but the existing trap cannot be raised without raising the connection in the wall.
