Convert draft vent WH to power vent?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by code0, Jul 30, 2007.
  1. code0
    code0 New Member
    Oct 8, 2006
    Webmaster
    Marshall County, Iowa
    I had my water heater replaced last December with a Ruud PH2-40PF (the old one finally got a leak). I replaced my furnace and A/C about a month ago - the A/C died and the furnace was about 30 years old.
    Anyway, the new furnace is a 95% direct vent model and all I have on the current chimney is the WH. At some point, I'd like to remove the chimney (the house is 50 years old - I think the current chimney is just metal vent pipe with no brick).
    Is there any way to add a power vent to this model, or does the unit need to be replaced with one that was designed for a power vent from the factory? Thanks!
    I will say right now that I had a draft vent unit installed since the old one was under home warranty and I couldn't afford the cost difference at the time. A new WH for $60 installed was a good deal in the winter.
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    no way
    you are out of luck.....
    you cant do that legally.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    Like MPM said you can't do it.
  5. jimbo
    jimbo Plumber
    San Diego, CA
    The control and safety circuits for a power vent are so complicated that the cost to retrofit them to an existing furnace would likely exceed the cost of a new furnace. Also, because it would be impossible to get AGA or GAMA certification on a retrofitted furnace, there are legal, code, and insurance issues. There may be companies who tell you they can do this. I would not go there.
  6. dubldare
    dubldare Plumber/Gasfitter
    Sep 14, 2005
    Plumber/Gasfitter
    MN/ND
  7. jimbo
    jimbo Plumber
    San Diego, CA
    Looks like commercial stuff. I would stand by my comment that the cost to put this on a residential unit would be prohibitive. Probably need a new gas valve, because the typical water heater gas valve does not have any kind of interface connections necessary for the safety circuits.
Similar Threads: Convert draft
Plumbing Forum, Professional & DIY Advice Converting downstairs living room to bedroom suite Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Converting Gravity Sewer to Overhead Nov 29, 2016
Plumbing Forum, Professional & DIY Advice Converting septic line cleanout (diagram\pic) for drain use Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Convert cast iron closet flange / elbow to PVC Oct 3, 2016
Plumbing Forum, Professional & DIY Advice Bathroom pipes go from 3/4 to 1/2 inch for total of 8 feet. will I benefit if I convert to 3/4 ? Aug 7, 2016
