Contolling Circulator Pump by water temperature
Discussion in 'Tankless Water Heater Forum' started by cicerored, Oct 7, 2013.
  1. cicerored
    cicerored New Member
    Aug 21, 2008
    Clay, New York, United States
    Hello,
    I need to install a controller or aquastat that will turn on/off my recirculation pump which is connected to my tankless water heater with external storage tank. I am looking for reocommendations.
    I am converting from an old boiler water to a high efficiency tankless unit (for commercial hot water). The new tankless unit heats water when it senses flow (unlike the old boiler). So when the water in the storage tank drops below about 110, I need the pump to turn on to create water flow to turn on the tankless unit. When the water temperature in the storage tank reaches about 130, I need it to turn off the pump to stop the tankless unit from firing.
    I kind of get the idea a 3 function aquastat is what I need (hi, lo, diff) but any help would be appreciated. Also, does the immersion bulb funtion as the thermostat on such an aquastat? The old boiler had an aquastat and immersion bulb, but it was wired up to the burner only. The circulator runs/ran all the time to the boiler and storage tank loop
    Oh, I the pump I want to contrl is an 1/6 hp lochinvar operating on 120v circuit.
  2. cicerored
    Aug 21, 2008
    Just wanted to update this with solution. I found a RANCO ETC-111000 which is like a digital version of an aquastat and includes a sensor. It is like a temparature controlled on/off switch.
Similar Threads: Contolling Circulator
Tankless Water Heater Forum Navien Tankless and Hot Water Circulator Jan 17, 2010
Tankless Water Heater Forum tankless water heater...circulator Oct 14, 2008
