BillTheEngineer
I have a High-ranch style of home, 3 heating zones, with fin and tube baseboard convectors. The boiling is a early nineties gas files 2 stage boiler (Raypak H3-0125B).
Recently I have been hearing one of the contactors making a bit of noise (Not sure which one, there are 4, one for each zone and one for the boiler control). It seems to be cycling really fast (multiple times a second). I had this issue before and it seemed to be linked to the original mercury thermostats. I have replace all the thermostats with electronic ones. Once replace the problem went away. But the noise seems to have returned.
So I am thinking it's the contactor that controls the hot surface ignition that is making the noise. Is this a sign that the temperature switches, ignition module, probe, fast response temperature sensor or something else is on its way out? Is there a way to tell diagnose which component it is other than replacing each on a trial and error?
My first winter in the home I had issues with the boiler making a groaning noise with seemed to be an issue that it was heating water faster than it could circulate it and causing boiling. I addressed this by disabling the second stage on the boiler. Since then the groaning has gone away and there has been no issues. I guess this also goes to show how oversized the boiler is if can heat sufficiently even on one stage.
There is another circulator out of view behind the water heater.
