Connecting new tub drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Denny Z, Nov 5, 2006.
  1. Denny Z
    Denny Z New Member
    Nov 5, 2006
    I'm redoing a second floor bath. Replacing tub area tile and tub. There is NO access door to the suppy lines and drain (other side is a bedroom).
    Can I install a new tub drain and overflow drain and connect securely without opening the bedroom wall ( or worse the celling below)?
    Also because of the weight, what is the incremental difficulty of making the connections if I choose a cast iron vs. a steel tub?
    Not starting the demolition until I know how BIG to make the dumpster!
    Thanks
  2. hj
    tub
    Plumbers connect the tubs without opening access all the time, but it takes some precise measuring, and possibly experience to know what to do. As far as cast iron or steel, the difference is in the longevity more than the weight, since you only install it once, but have to live with it until it goes bad. Which with a steel tub may not be too long, relatively speaking.
  4. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    You are going to have to open the bedroom wall. Make an acess panel. I would go with Americast or some equivalent.
  5. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    The easiest way to make an access panel is to cut out a very nice square of your drywall and to just replace this same square when you are done. If you do a good job, it should stay in place without too much fuss. If there's a stud or two under it, you can put a couple of screws in there to hold it in place.
    Use a dremel or rotozip with a drywall bit to cut it out, so you can set the depth just right. I recently had to cut out a wall to replace a shower faucet in a mobile home, and the toilet vent was pressed firmly against the drywall I was cutting out. Fortunately I had the depth set properly and I just scratched the pipe instead of cutting through it.
  6. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    It wasn't due to good fortune, it was good planning...:D
Similar Threads: Connecting drain
Plumbing Forum, Professional & DIY Advice Advice connecting additional shower to existing horizontal drain Mar 24, 2016
Plumbing Forum, Professional & DIY Advice Connecting Shower drain to the toilet drain Mar 6, 2016
Plumbing Forum, Professional & DIY Advice Connecting shower drain to a pitched toilet drain, help! Dec 12, 2015
Plumbing Forum, Professional & DIY Advice Connecting new lav drain to existing branch, relocating cleanout Oct 12, 2015
Plumbing Forum, Professional & DIY Advice Connecting 1-1/2" to 1-1/4" drain pipe Mar 21, 2015
