Connecting instant water heater to faucet
mfs54729
I had an Emerson E-340 instant water heater under our kitchen sink. The
heater developed a leak so I bought an Insinkerator SST-FLTR heater.
My faucet looks just like the H770-SS but the pipes are different. Only one
pipe is causing trouble though. The faucet has a 5/16" copper tube with a
compression fitting and the heater has a 5/16" barbed fitting. I can
fabricate a 5/16" barbed connector to 5/16" compression fitting. I just need
a piece of 5/16" piece of plastic tubing to go between the two barbed fittings.
I believe 7/16" polyethylene tubing has an inside diameter of 5/16". I cannot
find any 7/16" polyethylene tubing, only 1/2" or 3/8". I found some vinyl
tubing with 5/16" ID. Will that work or is the water temperature (190 F) too
high for that? Any ideas where I can find a short piece of 5/16" ID tubing that
will take high heat (190 F)?
Thanks.
Mark
